soilid axle swap f250
soilid axle swap f250 Empty soilid axle swap f250
Post  Bart Knox May 9th 2016, 7:13 pm
I a set of axles from a 79 f250 looking to swap them into my 92 f250. I broke the front axle shaft and cant find parts in Canada. I no it sounds crazzy but noware inventory's parts before 2000 everywhere crushed everything when scrap was up. It just for a work truck i was going to do a lift kit anyway. I don't care about brakes and stuff I'll make it work
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
soilid axle swap f250 Empty Re: soilid axle swap f250
Post  Bart Knox May 10th 2016, 8:12 am
I no I'd have to move the spring perches out a few inchs. Main thing im wondering is tie rods. I no theres going to be some cuting and welding thats no problem.
Bart Knox
Bart Knox
Post  supervel45 May 10th 2016, 11:14 pm
https://www.youtube.com/watch?v=W9O_TqyVYVg
I did not have time to watch the video but, hope it helps.
Post  supervel45 May 10th 2016, 11:18 pm
PS: There are a whole bunch of other video's in the link on the right side of the page. Bronco Grave Yard Co. seems to be the Man in this department also.
Post  Bart Knox May 11th 2016, 7:22 pm
There all the newer 90s front axles
Bart Knox
Bart Knox
Post  paperman May 11th 2016, 8:54 pm
So is there a question somewhere in there?
paperman
Post  Bart Knox May 13th 2016, 8:25 am
Has anyone done it? What are the main problems ill run into? Will the tierods work from the 92 with the 79 f250 axles? If not can I use the tierods from 79 with the newer steering?
Bart Knox
Bart Knox
Post  paperman May 13th 2016, 8:41 am
Not easy as the spring perch is cast into the housing. Anything can be done, the steering would be easy if you have a lathe or a good die set to cut the thread you need for the proper length links. Keep the 79 tie rod and bottom 1/2 of the drag link, then the new top 1/2 of the drag link. Cut and thread either one for the mating link and sleeve, cut the one that is right hand thread to make it easier.
paperman
