axle swap question....
axle swap question.... Empty axle swap question....
Post  racinghabbit March 14th 2014, 6:52 pm
Has anyone tried to put a superdutyf250 99-03 rear axle into and 1980's f250????
racinghabbit
racinghabbit
axle swap question.... Empty Re: axle swap question....
Post  schmitty March 14th 2014, 9:11 pm
Kind of a rough deal, because the book bolt patterns are different for the wheels.
Post  racinghabbit March 14th 2014, 10:21 pm
i'm was more worried about the leaf spring perch and shock mounts
racinghabbit
racinghabbit
Post  racinghabbit March 14th 2014, 10:34 pm
I run 16's boggers.. so super duty rims will work fine
racinghabbit
racinghabbit
Post  buttnuttn8 April 6th 2014, 2:44 pm
correct me if im wront but the super duty axles are ball joint correct?  as well as im not sure the frame width so you might have to fab up to make the points work.  anything is possible with a welder because I have a 79 and i put in an 88 dana 60 in swiched over to leaf springs and outriddged it so im sure it could be just how much I dont know without the measurements
buttnuttn8
Post  cool40 April 6th 2014, 3:26 pm
I hope to get a 60 from a 2005 for my 76.I don't figure the 44 will last long.
Post  racinghabbit April 13th 2014, 1:44 am
Here is my final result... I took a rear axle out of a 00 ford excursion and i had to use the yoke off my 1984 f250 10.25 rear axle..(fit perfectly... ))... Leaf springs aligned up just fine... put a new crush sleeve in it... so now i have 4 wheel disc brakes with factory parts... and 3.73 gears .... was a pretty sweet deal... never would have expected a yoke off a 84 to fit a 00.... just a heads up .. there is no cross over u-joint from a 00 and up rearend to a older driveshaft .... that is y i had to switch yokes
racinghabbit
racinghabbit
Post  schmitty April 13th 2014, 9:58 am
Good to know info there. Still wish Ford wouldn't have gone to an oddball bolt pattern though.
