Can anyone decypher this cam info?
I also have a crane cam, everything unknown except the following so do you guys have any idea of what it could be?
F266 / 3529 - 2 - 9
.35 - 31 - 97
970147
I have looked on their website and have had no joy
Thanks in advance
Jeff
F266 / 3529 - 2 - 9
.35 - 31 - 97
970147
Thanks in advance
Jeff
fozwanger- Posts : 25
Re: Can anyone decypher this cam info?
I found one that was close in my 1993 Crane Catalog,It's a Solid Flat Tappet Cam
Here's what the catalog shows F-266/3528-2-8
Duration at .050 266 int and 276 exh
Lobe Seperation 108
Valve lash .026-.026
Lift .603 int and .624 exh
Rpm Range 4400 to 7400 rpm.
Later Mark.
Lobe Seperation 108
Later Mark.
Mark Miller- Posts : 1959
Oo, Thanks Mark.
Qquite lively then. Bit too lively for the street?
Running DOVE C heads and a tunnel ram so would be quite well matched to the induction side of thengs then?
Cne said
PART 351511 ENGINE TYPE: MECHANICAL SPECIAL
GRINDN F-266/3528-2-8
ENGINE 1968-UP FORD-MERCURY V-8 370-429-460 CU.IN.
MODERATE COMPETITION ONLY, GOOD MID &
UPPER R.P.M. H.P.
VALVE SETTING: .026 EXHAUST .026 HOT
INTAKE @ CAM
3528 @
603 ROCKER ARM
INTAKE @ CAM
3648 @
624 1.71 ROCKER ARM
LIFT: EXHAUST @ @
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOS
CAM TIMING
OPENS
CLOSES
ADVERTISED
.020 EXHAUST INTAKE 47 BTDC 75 ABDC 302 ° °
TAPPET LIFT EXHAUST
88 BBDC 44 ATDC 312 °
SPRING
RECOMMENDED RPM
RANGE WITH
TRIPLE DUAL OUTER MATCHING
PART
99890 MINIMUM RPM 4400
LOAD CLOSE
131 LBS @ 1.900 O 1 29/32 MAXIMUM RPM 7800
OPEN:
370 LBS @ 1.330 VALVE FLOAT 8400
CAM TIMING
OPENS
CLOSES
MAX LIFT
DURATIO
@ .050 INTAKE
30 BTDC 56 ABDC 103 ° ATDC 266 °
TAPPET LIFT EXHAUST
71 BBDC 25 ATDC 113 ° BTDC 276
UPPER R.P.M. H.P.
INTAKE @ CAM
3528 @
603 ROCKER ARM
INTAKE @ CAM
3648 @
624 1.71 ROCKER ARM
LIFT: EXHAUST @ @
CAM TIMING
OPENS
CLOSES
ADVERTISED
TAPPET LIFT EXHAUST
SPRING
RECOMMENDED RPM
RANGE WITH
PART
LOAD CLOSE
OPEN:
CAM TIMING
OPENS
CLOSES
MAX LIFT
DURATIO
@ .050 INTAKE
TAPPET LIFT EXHAUST
» Roller Lifters SOLD!
» Need a 950 holley base plate
» what needed
» first big block build
» Starting to plan for the future
» what needed
