C6 fluid capacity with oil change ?
So it's a c6 with a new 9" converter
I just drained the pan, and put in new converter with 1 qt in the converter.
How much should she take to b full?
Also it has a tci 2 qt pan
rocketpony- Posts : 120
Re: C6 fluid capacity with oil change ?
A brand new build vs just an oil change, add in factors like pan size, convertor size, cooler size, etc.
I keep 4 gallons on hand for a new build. Typically a transmission will take 14 quarts (I have a massive cooler).
If it was me in your situation I'd fill the convertor as you did and put in 6-8 quarts, fire it up and top off as needed.
It's good to start small, just an oil change leaves a lot of fluid in the transmission.
Good luck
Drew
Good luck
Drew
DeepRoots- Posts : 110
Well , best idea would be , verify where the "FULL" mark is on the dipstick , needs to be just above the pan rail or at about the level where the o'ring in on the dipstick tube .
Then fill to the full marks at warm operating temp, motor running. Any other figure anyone tells you for an amount is a guess at best
Gregaust- Posts : 625
Gregaust wrote:Well , best idea would be , verify where the "FULL" mark is on the dipstick , needs to be just above the pan rail or at about the level where the o'ring in on the dipstick tube .
Yup, that is why no one really wanted to answer.... it's pretty much impossible to have an exact number.
