Ok to use vp110 to idle motor on? Just to flush out q16
Ok to use vp110 to idle motor on? Just to flush out q16 Empty Ok to use vp110 to idle motor on? Just to flush out q16
Post  rocketpony October 12th 2016, 10:25 am
i run q16 and the season is now over, so I want to run motor on a non oxygenated fuel . Only thing I have is sum vp 110. Would it be ok to just idle the motor on this fuel? Just to flush out?
It's a 15:1 cr
rocketpony
Ok to use vp110 to idle motor on? Just to flush out q16 Empty Re: Ok to use vp110 to idle motor on? Just to flush out q16
Post  rmcomprandy October 12th 2016, 10:27 am
rocketpony wrote:i run q16 and the season is now over, so I want to run motor on a non oxygenated fuel . Only thing I have is sum vp 110. Would it be ok to just idle the motor on this fuel? Just to flush out?
It's a 15:1 cr
SURE ...
Post  rocketpony October 12th 2016, 10:53 am
Thanks for the quick reply!
rocketpony
Post  BBFTorino October 13th 2016, 1:13 am
Yes. You could even run 87 octane pump gas in it for a few mins. because idle is not much load on it. It wont build a ton of cylinder pressure at idle.
Since you have a little 110 already, go ahead and use it. It isn't going to kill anything, not even if you whack the throttle a few times!!
Post  69F100 October 13th 2016, 5:30 am
I use 93 octane pump gas to crank and flush the engine when I run it. I run alky with a Ron's tolit with 14:7 cr. Like was said just don't run around with it just idling want hurt it.
Post  rmcomprandy October 13th 2016, 8:42 am
rocketpony wrote:Thanks for the quick reply!
As long as it is RV/marine type "pump gas" without ethanol in it.
DO NOT use normal pump gas to flush a fuel system for a long term storage.
Post  69F100 October 13th 2016, 9:28 pm
x2 on what Randy said the ethanol will srew up a fuel system if left in it. We have a couple of stores here that still sales none ethanol gas pay a little more at the pump but in the long run it is cheaper.
