oil pump block gasket
YA or NA !! Back when I run a pump in the pan I never used one -always sanded the foot flat and torqued to 45 ft/lbs .I run all dry sump motor so this question is not for me ! back in the '70's always sanded the foot of the oil pump and never used an gasket pump to block and never had a oiling failure because df it . OPTIONS????
Frank Merkl- Posts : 1524
Re: oil pump block gasket
Frank Merkl wrote:YA or NA !! Back when I run a pump in the pan I never used one -always sanded the foot flat and torqued to 45 ft/lbs .I run all dry sump motor so this question is not for me ! back in the '70's always sanded the foot of the oil pump and never used an gasket pump to block and never had a oiling failure because df it . OPTIONS????
That gasket is there because some blocks are rough or not completely flat in that mounting area.
If the block is flat and smooth there is no need for that gasket; just use a small amount of Hylomar type sealant; (a long time ago I used to use Number 2 Permatex from the tube).
» OIl pump gasket
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» Who runs a Moroso/Mr Gasket water pump drive kit?
» IDT Block Oil Pump Drive
» Mr.gasket electric water pump drive $45 shipped
