Cap walk problems
+39
powerstrokeace
sunvalley54
QtrWarrior
westsideford
4thHorseman
Outlaw5.0
Northwest outlaw
605FOX
DJOHAGIN
studly
138
EVE
342g
Bret Powell
racnrick
fastford600
61coon
DGS
torkair
blown473
hienergy557
D. Sea
Barney
Greg_P
43 posters
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: Cap walk problems
DGS wrote:Let it walk, not a huge deal, caps won't break. JMExperience.
No, they will break and do. I think you will hear from others on hear that will say the same thing. But as far as bearing damage by cap walk, as long as you have enough oil clearance to keep the bearing off the crank when it moves into the bolt and stops, your right, it's not a huge deal.
And I have seen them still running with the cap broken, and the bearings looked fine. But I still say look into main straps or a 4 bolt conversion if over 800 hp, if you want to feel warm and fuzzy.
IDT-572 wrote:Lem Evans wrote:Compared to Nicplaus Copernius.....Einstein was an idiot .
Wasn't Copernicus's grand father on his mother's side a Williams?
Nikolas Capernicus, 1473-1543. polish scientist who discovered the heliocentric universe. the Church was scandalized because it was against their policy that the universe was geocentric, from the calculations of Ptolemy. I think he may have been a Williams.
61coon- Posts : 1824
61coon wrote:IDT-572 wrote:Lem Evans wrote:Compared to Nicplaus Copernius.....Einstein was an idiot .
Mean SOB I thought he was a WILLAMS
I though he was the guy who invented Kolbasa!!!!61coon wrote:IDT-572 wrote:Lem Evans wrote:Compared to Nicplaus Copernius.....Einstein was an idiot .
Guy's I have a regarding the cap Straps. When you install the cap straps,Does the engine need to be line bored ? And does the straps absolutely need to be made from TOOLED STEEL?
Yes you should line hone the mains ( not necessary to line bore) when using straps and IMO I'd use a high grade of steel, it's not that expensive as you only need 5 short pieces.bbf-falcon wrote:Guy's I have a regarding the cap Straps. When you install the cap straps,Does the engine need to be line bored ? And does the straps absolutely need to be made from TOOLED STEEL?
Maybe they won't break if YOU are not making any serious power.
Charlie
c.evans- BBF VENDOR SPONSOR
Thanks Davedfree383 wrote:Yes you should line hone the mains ( not necessary to line bore) when using straps and IMO I'd use a high grade of steel, it's not that expensive as you only need 5 short pieces.bbf-falcon wrote:Guy's I have a regarding the cap Straps. When you install the cap straps,Does the engine need to be line bored ? And does the straps absolutely need to be made from TOOLED STEEL?
I wonder would you still get cap walk if the 2 bolts were splayed instead of straight up and down?
I know it can't be done, but it would be interesting to find out. Cheers Colin
hienergy557- Posts : 179
hi welcome, thanks for imput but u must drive a geo metro ,or u would all ready know that the caps will break
and not huge deal if they cap walk, well i am hope that u never get to tune or build any race motor for any body that i know because u dont know s##t.
you need to read up on a bbf before the wolfs get u at the bar!!!!!!!!
p.s. if the evean's tell you it will happen you can take it to the bank!!!!!!!!!!
p.p.s have a nice day!!!!!!!!!!!!!!!!
logan
fastford600- Posts : 391
Guys,
I appreciate any and all opinions on this. Everybody has had different experiences, and the good thing about a site like this is that all opinions are generally valid and have merit.
The cap strapping sounds interesting to me. I presume the caps are milled flat on top and bar stock is placed over the cap between the bolts?
Greg_P- Posts : 1009
As far as line honing after adding the straps, just torque them to spec and check the housing bore. I have done them on 2300 ohv ford 4 cyl and 302's and not had to hone them.
Greg , yes mill the top of the cap flat, As far as the material , I just made the caps thick enough that cold roll was fine.
Also Hienergy, splayed main bolts I feel would probably stop it as it would pull the sides of the caps tight into the register. I think the reason BBC 's don't have cap walk issues as bad as the BBF with their 2 bolt caps is it has a much larger foot print ( more cap outside the bolt pattern )
JMHO
JMHO
What thickness do you recommend?
min. .625
The force of the crank pushing staight down and the bolts clamping on an inclined angle, less chance of the bolt streching. That's why the splayed 4 bolt conversion is better than 4 bolt SCJ cap to stop cap walk.
Cheers Colin.
Cheers Colin.
Greg_P wrote:Guys,
Greg,
Here is some pictures of the straps and how the caps are machined.
https://www.429-460.com/stuff-for-sale-f1/wtb-main-stud-kit-2-bolt-dove-a-t2256.htm#24007
racnrick- Posts : 462
Awesome, thanks for the pics...now I'm clear on what the straps do and how they fit.
Too bad I didn't get educated till after they sold, though!
Greg
Greg
Thanks for the cap strap edumacashun...
Greg,
I've got a block that has worse cap walk than that. Everyone and their grandma looked at it at the Bash and all agreed to just hit the caps and saddles on a honing stone to knock the high spots, throw some anti-sieze in there and torque them down extra snug with studs and I'll be fine... That's what I'm going to do...
My thought is it's not walking anymore, but probably did when the tune was off. OR it might be walking on the initial hit of the bottle...
Greg,
jbozzelle- Posts : 3705
billandlori wrote:richter69 wrote:Put the good crank in it, a little anti sieze between the caps and block, start saving for an aftermarket IMO.
Jon, does the anti sieze just allow the caps to do what they are gonna do with out the metal transfer?
Bill
Anyone??
billandlori- Posts : 2081
Put a good set of aluminum rods in it, ARP studs torqued to about 105-110 w/molly, have it line honed, and STOP already with the lean tunes!
Bret
Bret
Bret Powell- Posts : 133
I asked that question today, and thats what I was told, they will still walk, just won't gall.
Last edited by 342g on December 11th 2009, 12:39 am; edited 1 time in total (Reason for editing : caps)
342g- BBF CONTRIBUTOR
342g wrote:I asked that question today, and thats what I was told, they will still walk, just won't gall.
10-4 Thanks!!
Bill
I had this same problem. at 1016rwhp its time for an A block before I drive through my own oil again on the big end.
EVE- Posts : 124
i am a firm beliver in the lean tune up you just have to pull some timing BBF dont like that much timing anyway lean it out and pull some timing
studly- Posts : 512
» 460 cap walk
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» cam walk
» cap walk
» How much cap walk is acceptable ?
» cam walk
» cap walk
Page 2 of 5
