Truck comparison
Truck comparison Empty Truck comparison
Post  IDT-572 January 26th 2017, 11:42 am
Is it worth the difference? F250 vs F350 SRW
Truck comparison Empty Re: Truck comparison
Post  Lem Evans January 26th 2017, 11:51 am
Auxiliary rear springs and stabilizer bar are most of it.
Post  IDT-572 January 26th 2017, 11:54 am
Brakes any better?
Post  jasonf January 26th 2017, 12:19 pm
** Edited** Everything is mostly the same, verified countless time on Ford-trucks.com with Ford part numbers for the springs, shocks etc showing the exact same parts. Regarding the stabilizer, they seem optional depending on what package of truck you have. Mine is an FX4 and has no rear stabilizer at all. Mine is an 03 F350 SRW.
Post  Lem Evans January 26th 2017, 12:37 pm
If the power train and the tire size are the same the gear ratios of both models will be the same.
The aux. springs and stab. bar can be had on the F250 by adding the camper pkg.
Post  Lem Evans January 26th 2017, 12:39 pm
CAMPER PACKAGE (471)
Availability:
● Optional on all Pickups
Not available with:
● 20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio
(on 4x4 w/17" or 18" tires) or Heavy-Service Front Suspension
Package (67H)
Includes:
● Extra heavy-service front springs (4x2) (2 up upgrade above the
spring computer selected as a consequence of options chosen. Not
included if maximum springs have been computer selected as
standard equipment)
● Heavy-service front springs (4x4) (1 up upgrade above the spring
standard equipment)
● Rear auxiliary springs (F-250 only; Std. on 350)
● Rear stabilizer bar (SRW only)
● Slide-in camper certification
Post  Lem Evans January 26th 2017, 12:40 pm
F-250 TRAILER TOW PACKAGE – HIGH CAPACITY (535)
Availability
● Optional on F-250
Not available with:
● 10,000 GVWR/9,900 GVWR Pkg. (68D)
Requires:
● 6.7L Power Stroke® Diesel engine (99T)
Includes:
● Increase GCW on diesel engine from 23,500 lbs. to 25,700 lbs.
● Upgraded axle
● 20” Polished Aluminum (64U) – Platinum only
Post  Lem Evans January 26th 2017, 12:45 pm
x
Post  jasonf January 26th 2017, 1:08 pm
Edit double post for some reason.
Post  jasonf January 26th 2017, 1:09 pm
Lem Evans wrote:If the power train and the tire size are the same the gear ratios of both models will be the same.
I have always wondered what the camper package entailed. Anything else besides a sway bar?
What year are you looking for Blake?
Post  jasonf January 26th 2017, 1:11 pm
The very first couple of posts in the thread below have a vin decoder in case you are looking at a specific vehicle... along with a ton of other tech.
http://www.ford-trucks.com/forums/1154670-superduty-tech-folder-and-faq.html
Post  mudtrucker January 26th 2017, 1:54 pm
I would look for the best deal for the truck that you wanted and if you found that the suspension wasn't heavy enough throw a set of air bags on it and roll! Most any modern trailer will have brakes, so a run of the mill F250 is going to be more than enough unless your pulling a big heavy goose neck then you would be better off with a daully anyways.
mudtrucker
mudtrucker
Post  D. Sea January 27th 2017, 9:19 am
DRW > SRW Very Happy
D. Sea
D. Sea
Post  IDT-572 January 30th 2017, 4:49 pm
This is for anew truck at work with a service bed. The F250's are loade with just the bed and tools. What I found was standar vs standard was 1100 more payload on the F350 plus block on the axle to spring was 4" 250 is 1 1/2 "
Post  Lem Evans January 30th 2017, 8:36 pm
With a service bed the SRW F350 is the only way to go. Is the bed a 8 or 9 foot bed?
Get every friggin' HD option available.
Post  IDT-572 January 31st 2017, 10:04 am
Its an 8 ft bed, and the cost isn't much more. The extra rake, (higher in the back will help too when loaded).
By the time they get all the tools and supply's they carry daily, a 250 is riding low in the rear. Then if a transformer is loaded or a reel of wire, it sway city.
Post  Lem Evans January 31st 2017, 10:55 am
IDT-572 wrote:Its an 8 ft bed, and the cost isn't much more. The extra rake, (higher in the back will help too when loaded).
So, you are going with the bed delete option rather than the cab and chassis?
Post  IDT-572 January 31st 2017, 11:43 am
Yes sir.........
Post  mr.horsepower February 1st 2017, 12:05 am
IDT-572 wrote:Brakes any better?
250's vacuum boost, 350's hydro-boost? I've had a couple of each and that's the way they were, definitely tell a difference in the feel of the pedal
mr.horsepower
mr.horsepower
Post  IDT-572 February 1st 2017, 10:07 am
I think the gas 350's are vacuum. From what I have read. Only the diesel 350's are hydro-boost.
Post  mr.horsepower February 1st 2017, 11:22 am
Yes, was under the impression we talking diesel only Very Happy
mr.horsepower
mr.horsepower
Post  jones February 5th 2017, 8:12 pm
I have a question no one has been able to answer for me.
I have been looking at the XL F550 & F450 and they both have a "High Clearance" option. Is this a option that raises the truck for ground clearance or is it the option to lower the truck like if you was putting a wrecker bed on? Dealer seem to think is was a lowering option, just doesn't sound right if it's a lowering option. (They have never selected that option for the chassis cabs.)
jones
Post  jones February 6th 2017, 2:36 pm
The only reason I am looking at the F450 & F550 is weight, stronger drivetrain and ground clearance. I don't really need a flat bed but I do need a lot of storage for chains, air compressor and I hope to get a small hyd boom to load items in the bed. Did I mention the added weight? The trucks drive and stop so much better the heavier they are. Of course I have been wanting on for 15 years now.
jones
