Bad luck or bad lifter(s)? Cup came out
STR-LGL-70
SLord82
Bad luck or bad lifter(s)? Cup came out Empty Bad luck or bad lifter(s)? Cup came out
Post  SLord82 February 18th 2017, 5:55 pm
I was breaking in a new cam in a fresh build and to my horror I could hear a loud ticking after a few minutes of running.
Long story short I pull off the intake and found one lifter with the cup sitting sideways next to the pushrod.
What may have caused this? Bad lifter(s)? Maybe I didn't set the preload correctly? These were new comp hydro lifters. Can is new too. Luckily the cam looks fine and the lifter face looks fine too.
Should I get a new lifter? Or try to put it back together?
SLord82
Bad luck or bad lifter(s)? Cup came out Empty Re: Bad luck or bad lifter(s)? Cup came out
Post  SLord82 February 18th 2017, 6:00 pm
Bad luck or bad lifter(s)? Cup came out GM56gnT
SLord82
Post  STR-LGL-70 February 18th 2017, 6:33 pm
I may be wrong,,, but isn't there supposed to an E clip or some sort of snap ring that holds the lifter together?
If there is, did you find it?
Sheldon
STR-LGL-70
STR-LGL-70
Post  SLord82 February 18th 2017, 6:53 pm
These are comp 832 lifters. They have this wire clip not an E clip
Bad luck or bad lifter(s)? Cup came out BncxFPC
SLord82
Post  SLord82 February 18th 2017, 7:09 pm
I need a new intake gasket anyway, might as well order a single lifter too for peace of mind.
Anyone have any idea why this may have happened?
SLord82
Post  BOSS 429 February 18th 2017, 9:13 pm
preload too loose
Post  rmcomprandy February 19th 2017, 12:36 am
BOSS 429 wrote:preload too loose
OR, floating the valve or it sticking in the guide.
Post  SLord82 February 19th 2017, 1:02 am
I doubt it floated the valve, it never got over 2k.
Thanks for the feedback guys.
SLord82
Post  BBFTorino February 19th 2017, 1:24 am
Pushrod too long on that lifter??
Post  SLord82 February 19th 2017, 2:43 pm
BBFTorino wrote:Pushrod too long on that lifter??
So just that valve needs a shorter pushrod?
SLord82
Post  SLord82 February 19th 2017, 2:44 pm
Have you seen it happen before or is this a guess?
SLord82
Post  69F100 February 19th 2017, 5:16 pm
I have had that happen to me years ago at the track with my 69 Mustang but I flooted the valves. You might want to check that valve and make sure it not sticking for some reason.
Post  BOSS 429 February 19th 2017, 5:40 pm
about 30 times, that i can rem, very common, just saw a guy I know do this very thing. I told him to put the lifter back together and set the valves right, nows its been fine for a few weeks. how loose were others?
Post  BOSS 429 February 19th 2017, 5:41 pm
stud mounted rocker?
Post  SLord82 February 19th 2017, 11:25 pm
Thank you for the feedback.
The other valves were not loose that I noticed, though I accept I may have set one valve incorrectly.
I went ahead and ordered another lifter, it was only 7 bucks and I needed an intake gasket too. I'll recheck the preload on all lifters now.
Adjustable rocker setup, with comp magnum rockers and Manley guide plates on dove heades
SLord82
