Timing with A460 heads
We are on a 92 jet with a cross hair plate. Anyone spraying equivalent with these heads. What kind of timing are you able to run. The motor is a nitrous built 598.
chuck- Posts : 414
Re: Timing with A460 heads
hey chuck this is Larry Wilson give me a call 229 8542096
larry552- Posts : 335
larry552 wrote:hey chuck this is Larry Wilson give me a call 229 8542096
I'll call you tomorrow.
chuck- Posts : 414
On a 250 shot I run 38 an pull 6 on the nitrous. I like the ford motorcraft plugs . I have tried other brands and they just don't respond as well but they do crack after about 3 or 4 pulls for cleaning and resetting gap sometimes.
6jeff6- Posts : 279
chuck wrote:We are on a 92 jet with a cross hair plate. Anyone spraying equivalent with these heads. What kind of timing are you able to run. The motor is a nitrous built 598.
Is that a 92 jet in each cross bar?
68formalGT- Posts : 865
» Cometic MLS head gaskets
» question on compression ...using pump gas (a460...using fms a460 heads)
» Question about TFS A460 and Motorsport A460 heads
» BBF PARTS - B460 Heads, A460 HEADS - MUCH MORE
