What brand for vacuum pump? Is much difference?
460pulling
rocketpony
What brand for vacuum pump? Is much difference? Empty What brand for vacuum pump? Is much difference?
Post  rocketpony March 10th 2017, 11:19 pm
So this is my first vacuum pump setup, what would b top 2 or 3 choices for vacuum pump? Is it much difference?
I want sumthin good , but not crazy expensive if possible.
It's for c headed 600ci, wet sump, on gas
rocketpony
What brand for vacuum pump? Is much difference? Empty Re: What brand for vacuum pump? Is much difference?
Post  460pulling March 11th 2017, 9:04 am
Star machine and Moroso make good pumps.
460pulling
Post  rmcomprandy March 11th 2017, 11:45 am
I use the pumps from "G Z Motorsports" but, all of the true race pumps will do the necessary job.
Post  Doug Rahn March 11th 2017, 12:13 pm
I noticed in your post you're using a wet sump, so whichever pump you decide to use make sure you're not pulling to much vacuum. Otherwise your oil pump and vacuum pump will be competing with each other and the oil pressure will fluctuate like crazy.
Post  dfree383 March 11th 2017, 10:06 pm
Star pump here
Post  rocketpony March 12th 2017, 2:58 pm
Thanks again!!!
rocketpony
Post  HorsinAround March 13th 2017, 2:03 pm
rmcomprandy wrote:I use the pumps from "G Z Motorsports" but, all of the true race pumps will do the necessary job.
X2 here
http://www.frontpagefab.com
Post  BBFTorino March 14th 2017, 12:38 am
There is a difference.....avoid the ones that say "Made in China"
