Hyd. FT cam for vacuum class truck puller
Hyd. FT cam for vacuum class truck puller Empty Hyd. FT cam for vacuum class truck puller
Post  Green 72 July 15th 2017, 11:19 pm
This is a all cast class. 466 with flat tops,.040 quench,C8 ported heads,SCJ intake and truck manifolds. Need some suggestions on cam. Need to pull 14 inchs vacuum.
Green 72
Hyd. FT cam for vacuum class truck puller Empty Re: Hyd. FT cam for vacuum class truck puller
Post  rmcomprandy July 15th 2017, 11:48 pm
Green 72 wrote:This is a all cast class. 466 with flat tops,.040 quench,C8 ported heads,SCJ intake and truck manifolds. Need some suggestions on cam. Need to pull 14 inchs vacuum.
Not enough information:
1. what actual compression ratio ?
2. what diameter valves
3. What intake manifold modifications ?
4. what carburetor ?
5. Exhaust Manifolds ... what size pipes ? mufflers ?
6. how much ignition timing does the vacuum advance have and add to that RPM mechanical advance ?
7. at what RPM is that amount of vacuum needed ?
8. hydraulic or solid lifter ?
9. valve train and cylinder head valve lift limits ?
Post  Green 72 July 16th 2017, 12:17 am
Randy CR should be 11.5,2.19 1.71 valves,intake has opening modified to just devider in center not 4 holes,has to be single inlet carb,exhaust wil be 2 1/2 with straight thru mufflers do not know about timing,heads have 930 Com Cams springs but can be changed if needed any help Randy would be a great help.Thank in advance.
Green 72
Post  Green 72 July 16th 2017, 12:21 am
Randy vacuum needs to be at 1000 rpm and it is hyd.cam. Thanks for your quick reply.
Green 72
Post  rmcomprandy July 16th 2017, 10:42 am
Something custom would certainly be best however, with vacuum advance adding 20 degrees at 1,000 rpm, a catalog Lunati Grind # 61003 VooDoo would work; part number 10340703.
Post  Green 72 July 16th 2017, 11:09 am
Thanks Randy
Green 72
Post  rmcomprandy July 16th 2017, 6:24 pm
Green 72 wrote:Thanks Randy
I was quoting from memory ... the actual Grind # is 61603; the part number is correct.
Post  Straubtech July 17th 2017, 8:58 am
These vacuum rule classes are the truest testament to the phrase "Devil's in the Details". To get these cams right you need to do the following: Flow the induction and flow the exhaust....meaning the heads need to be flowed on the intake side with the carb, intake and heads bolted as 1 on the flow bench. Then the exhaust with the headers to be used. Engine combination being used must be detailed.
If the above is done then the truck will be exceptional.
Straubtech
Hyd. FT cam for vacuum class truck puller Empty hyd-ft-cam-for-vacuum-class-truck-puller
Post  Alpine2013 July 17th 2017, 9:59 am
Rhoads Lifters do a great job of increasing vacuum at idle by reducing lift and duration at low RPMS/ idle. You need an adjustable valve train to use them.
http://www.rhoadslifters.com/
For all racing applications, our  V-Max Variable Duration Lifters are the answer. They increase low-end torque and engine vacuum up to 50% more than Original Rhoads Lifters...and they rev higher too. This makes them the best choice for all racing applications. Typical vacuum increases range between 2 to 4 inches at idle when used with bigger cams. They are fully adjustable and require an adjustable valve train. Adjustment is similar to solid lifters.
Alpine2013
Alpine2013
