holley billet fuel filter
what direction of flow does the element face with the internal spring? haven't been able to find directions. thanks for your help.....bob
zbob- Posts : 271
Re: holley billet fuel filter
zbob wrote:what direction of flow does the element face with the internal spring? haven't been able to find directions. thanks for your help.....bob
Are you talking about the ones in the fuel bowls behind the inlet nut? If so, the spring goes in first and tit faces the fuel line side. If it is and inline filter I would think the spring would go on the outlet side also.
supervel45- Posts : 4497
https://www.poormanmotorsports.com/product/holley-billet-fuel-filters-10-micron
Check this link, If this is what you are talking about, the filter drops in first towards the outlet side with the tit facing up, then the spring next.
thanks, the second one is the filter I have. so in case I am a dumass> the fuel flow would pass from the outside of the screen element to the center and then out the end.
,,,,if that is correct I have been putting them in wrong. bobn
zbob- Posts : 271
zbob wrote:thanks, the second one is the filter I have. so in case I am a dumass> the fuel flow would pass from the outside of the screen element to the center and then out the end.
Seems ass backwards to me also. Holley shows it the same in their video also at the 45 second mark.
https://www.youtube.com/watch?v=3ssIOdtSu54
The outside surface of the filter element has more surface area so it would take longer to clog. Right?
4604X4- Posts : 108
in my best bugs bunny voice> what a maroon.
I now stand corrected.
zbob- Posts : 271
» Holley fuel bowl inlet filter
» WHAT'S PLUGGING UP MY FUEL FILTER ??
» fuel pump filter.
» Black Holley billet metering blocks $100
» flex fuel filter change
» fuel pump filter.
