Whats the right stall
I have a foxbody with a 605 and pg trans. peak hp 1050 at 6800, peak torque 850 between 59-6200.
My problem is I flashed the converter at 6000 rpms, does that sound to high? The weight of the car is
2650 lbs with me in it, 4.10 gear.
mustang557- Posts : 58
Re: Whats the right stall
I've read 300 rpm above peak torque
Hardy- Posts : 107
Mine is about 6500 with almost exact setup as you. Car is around 2600 with me in it.14x32 tire 4.86 gear and 1.80 glide. I shift @ 7800
Doesn’t sound too high to me. Flog it and see if it needs a tweak.
maverick- BBF CONTRIBUTOR
» stall speed Vs. stall ratio ...?
» nitrous stall
» Stall too loose??
» The stall
» need stall converter
» nitrous stall
» Stall too loose??
» The stall
