A460 Heads
DanH
Big Rick
Re: A460 Heads
I've seen early heads cut to 65 cc, no problems at 14 to 1 cr
DanH- Posts : 1081
Re: A460 Heads
Absolutely
Re: A460 Heads
The early SVO A heads can. My small motor has a set cut to 72cc..
QtrWarrior- Posts : 2703
Re: A460 Heads
OP, and anyone else, when you say A460 heads, are you talking about Trick Flow A460 heads, or is there another A460 head that I'm not aware of?
nickpohlaandp- Posts : 157
Re: A460 Heads
Big Rick wrote:can the A460 heads be safely cut to 75cc? Thanks
If you do, be prepared to deal with intake manifold fitment and valve to piston issues.
Re: A460 Heads
Actually there is only one "A460" head. Ford's M-6049-A460. All of the others are A460 style heads.
I'm surprised you don't know this.
Re: A460 Heads
there was other A460 type heats know as Extreme Machine EX 514 and IDT 460 heads. They are not made today.nickpohlaandp wrote:OP, and anyone else, when you say A460 heads, are you talking about Trick Flow A460 heads, or is there another A460 head that I'm not aware of?
DanH- Posts : 1081
Re: A460 Heads
DanH wrote:there was other A460 type heats know as Extreme Machine EX 514 and IDT 460 heads. They are not made today.nickpohlaandp wrote:OP, and anyone else, when you say A460 heads, are you talking about Trick Flow A460 heads, or is there another A460 head that I'm not aware of?
Gotcha. My friend has the EX514's. I'm not used to so many different heads being referred to as "A460". This is how I'd end up buying the wrong crap if I'm not careful, lol
Re: A460 Heads
The "A460" and your friends EX514 heads are a similar style head, in that they are completely different architecture than a stock type head.
The stock style heads have round intake ports and are a relatively low entry angle into the port.
The A460 as well as the B, C, D, and E460 stuff is raised square/rectangle port and raised square port exhaust.
http://www.edelbrock.com/automotive/mc/cylinder-heads/images/60669.jpg
This is a stock type of head. This one is an Edelbrock^^^
http://www.totalengineairflow.com/wp-content/uploads/wpsc/product_images/355_460.jpg
This one is a totally different animal. The A460 style head.
BBFTorino- Posts : 999
Re: A460 Heads
BBFTorino wrote:The "A460" and your friends EX514 heads are a similar style head, in that they are completely different architecture than a stock type head.
There's no mistaking those. So the SCJ aluminum heads I just put on that Torino would be considered a "stock" type head?
Re: A460 Heads
Stock type of architecture, yes. That means factory, and common aftermarket parts will bolt on to those heads...like intakes, headers, etc.nickpohlaandp wrote:BBFTorino wrote:The "A460" and your friends EX514 heads are a similar style head, in that they are completely different architecture than a stock type head.
The A460 heads need a dedicated A460 intake, and either modified BBC headers, or custom built.
Re: A460 Heads
BBFTorino wrote:Stock type of architecture, yes. That means factory, and common aftermarket parts will bolt on to those heads...like intakes, headers, etc.
OP, sorry to thread jack a little, I hope you don't mind.
So that makes sense, the stock architecture bit, because the intake gaskets I installed like they were made for the SCJ's. One thing I noticed when looking for an intake was some said "will not fit CJ". I knew the TF A460's require the TF intake, or something custom made, but back to stock stuff, is there any obvious visual port difference between the CJ and non-CJ head?
Re: A460 Heads
https://2img.net/h/i109.photobucket.com/albums/n57/jrocco_2006/460%20Engine%20Related/P4183020.jpg
Yes. This motor has the standard 'small port' passenger car heads.
http://www.survivalmotorsports.com/images/Blue_Thunder_Cobra_Jet_Chevy_Exhaust_Intake_Side2.jpg
And this is an updated aluminum version of the factory iron CJ/SCJ head.
Re: A460 Heads
Opps!!...these are the standard small port heads..............
http://www.powerperformancenews.com/wp-content/uploads/sites/4/2015/08/61.jpg
» question on compression ...using pump gas (a460...using fms a460 heads)
» Cometic MLS head gaskets
» Question about TFS A460 and Motorsport A460 heads
» BBF PARTS - B460 Heads, A460 HEADS - MUCH MORE
