Early Bronco Midplate
Early Bronco Midplate Empty Early Bronco Midplate
Post  t120r October 19th 2017, 5:21 pm
I have a 1/4" Aluminum motor plate, stock ZF motor mount and will be installing limiters. My question is, do I need a midplate? It's a hopped up 429, ZF 5-speed/NP205 in a Fiberglass '66 Bronco. It will seriously be a pain to mount it, but I will if absolutely necessary. Anyone have have opinions?
t120r
Early Bronco Midplate Empty Re: Early Bronco Midplate
Post  maverick October 19th 2017, 5:53 pm
Sounds like it's intended to be flogged. I'd use the midplate.
Post  t120r November 6th 2017, 3:12 pm
I erred on the safeside and went with midplate mounts. Was a pain in the butt to fabricate, but they're done now.
Early Bronco Midplate Sneb6f
t120r
Post  TravisRice November 6th 2017, 4:02 pm
Just an option but you can do some hiem joints with tubing to the transmission bolts as long as they are angled upward on both sides. I've done that before where a midplate is near impossible to get in. Frees up a lot of room. I'd upgrade to grade 8 bolts however.
Post  t120r November 6th 2017, 10:12 pm
That would have been a much easier idea.Smile But I'm all done now. The bolt that secures it throuh the frame is also where a 1/2" heim joint will go for the limiter.Smile
t120r
