Starter for 184T & ZF
I have a ZF and a 184 tooth neutral balanced flywheel. The 184 tooth flywheel is the same diameter as the original 180T ZF flywheel, just more teeth. Will the late 80s/early 90s manual starters work with this?
t120r- Posts : 96
» Starter wiring , with solinoid on starter and fender
» I need a new starter....
» What Starter do you use?
» Starter????
» starter and oil pan
» Starter????
