indexing spark plugs
cobrakid8
indexing spark plugs Empty indexing spark plugs
Post  cobrakid8 December 4th 2017, 4:22 pm
I have a question, The BBC that i have the prior owner indexed the spark plugs, he marked where the strap is and drew a line and they all sit around (1:00 o'clock position). We took all plugs out because we thought maybe the motor had hydro-locked the other night. Took each plug out and put them to the side exactly as they had came out exact order and with same amount of washers. So after turning motor over (after fixing the starter) I put the plugs back in and all went back exactly as they came out except one that is now 180 degree's out (like 7) from where it was lined up before. I added another washer and it still tightened up somehow 180 degree's from where the mark is supposed to be. so my question is what could be causing this and how bad would it hurt to just tighten it up and leave it 180 degree's out because i don't want to just remove the only washer that the plug has on it. Thanks!
cobrakid8
indexing spark plugs Empty Re: indexing spark plugs
Post  BBFTorino December 5th 2017, 12:45 am
Iron or aluminum head??
Post  dfree383 December 5th 2017, 6:04 am
Does the motor turn over fine with out plugs?
Post  cobrakid8 December 5th 2017, 8:02 am
Aluminum Dart heads and yes the motor turns over fine without the plugs in it. It supposedly has 15/1 compression, but I am lost on why the plug didn't go right back in since it was the one that came out and only had one washer on it.
cobrakid8
Post  Doug Rahn December 5th 2017, 8:25 am
Maybe the threads are starting to pull out of the head.
Post  cobrakid8 December 5th 2017, 11:23 am
Lord, i hope not, finally found a ford motor to trade for this weekend and I dont need the hassle of this thing now having problems lol
cobrakid8
Post  dfree383 December 5th 2017, 10:10 pm
Doug Rahn wrote:Maybe the threads are starting to pull out of the head.
that wouldn't cause a clearance issue, have you tried a colder plug?
Post  cobrakid8 December 5th 2017, 10:21 pm
Changed the plug tonight and after adding a washer it was close enough for government work.
cobrakid8
Post  Doug Rahn December 6th 2017, 9:11 am
Did I miss something in his original post about a clearance issue? All I saw was an issue with one plug returning back to it's original index location.
Post  Curt December 6th 2017, 9:49 am
cobrakid8 wrote:Changed the plug tonight and after adding a washer it was close enough for government work.
If the piston isn't closing the gap, you're wasting time.
indexing spark plugs Empty SAME....
Post  duggy2145 December 9th 2017, 1:18 am
From what I read the starter was causing the lock up... and has been fixed. Just a question about indexing a plug electrode.....
duggy2145
Post  cobrakid8 December 9th 2017, 4:38 pm
Yes, the starter caused motor not to start, that's been fixed it was just that after getting that fixed the plugs weren't lining up. That's not been pretty much fixed and I go tomorrow hopefully to trade this for a different motor that's a BBF.
cobrakid8
