cylinder bore
cylinder bore
heads i have have 70 stamped on them ford motorsports aluminum . right now have 440 bore...how big of bore will these heads accept ?
o henry- Posts : 33
Re: cylinder bore
bore out to the max 4.899 inch. Your question is backwards. How small a bore would be correct.o henry wrote: heads i have have 70 stamped on them ford motorsports aluminum . right now have 440 bore...how big of bore will these heads accept ?
DanH- Posts : 1081
Re: cylinder bore
Answered your PM. How it works is the larger the bore the better the head works. The smaller the bore limits the very large valves used on some of the aftermarket heads
DanH- Posts : 1081
» valve to cylinder bore/block clearance
» Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
» A-460 BORE
» Cyl Bore ?
» Bore a 460
» A-460 BORE
» Cyl Bore ?
» Bore a 460
