Oil Drain backs
+10
bigford632
Albert Clark
CDMBill
EverySparePenny
14 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Oil Drain backs
Unfortunately it looks like the oiling issues ended badly.
bigford632- Posts : 42
Re: Oil Drain backs
Things did end poorly last night. Oiling issue had been remidied with winter freshening. Never held less than 70 psi at rpm this year.
Sent from Topic'it App
EverySparePenny- Posts : 114
Re: Oil Drain backs
EverySparePenny wrote:Things did end poorly last night. Oiling issue had been remidied with winter freshening. Never held less than 70 psi at rpm this year.
Sorry man been there it's not fun.
Re: Oil Drain backs
Sucks but such is the the game. Bigger badder better time
Re: Oil Drain backs
So what happened??...did it blow up at the track??
BBFTorino- Posts : 999
Re: Oil Drain backs
It did. Not sure on extent of damage but #8 rod is not where it is supposed to be. Neither is the coolant or the oil.
Re: Oil Drain backs
https://youtu.be/cHm0_WsgJRA
Re: Oil Drain backs
Damn, that is a very nice truck, there Brother!! Sounded very good during the pull.
Re: Oil Drain backs
Thank you. Truck was on a mission still had some momentum after the engine died
Re: Oil Drain backs
EverySparePenny wrote:Thank you. Truck was on a mission still had some momentum after the engine died
Did you win sounds like you had the lead?Sucks that the engine blew though!!
Mark Miller- Posts : 1955
Re: Oil Drain backs
I did not. I was only the fourth truck down the track of 14. I was at 299 and change first place truck was 324 and change. I ended up 6th.
Re: Oil Drain backs
what rods where you running in that engine?
Re: Oil Drain backs
Eagle, H beams. Purchased nearly 10 years ago but only have 1.5 seasons of use.
Re: Oil Drain backs
EverySparePenny wrote:Eagle, H beams. Purchased nearly 10 years ago but only have 1.5 seasons of use.
Do you remember the Bob weight? Weight of the pistons?
You where having issues with bearings correct?
Re: Oil Drain backs
I do not off hand.
Had oil pressure issues last season but never any failure, all wear surfaces actually looked pretty good.
I'll try to round up that balance info
Re: Oil Drain backs
Hopefully this works and is legible
Re: Oil Drain backs
since you need to do a new rotating assembly, I'd work on getting that bob weight down.
Re: Oil Drain backs
This area is somewhat greek to me, but you mean lighter piston/rod combo, correct?
Re: Oil Drain backs
EverySparePenny wrote:This area is somewhat greek to me, but you mean lighter piston/rod combo, correct?
Yes including the crank shaft, with the way you guys are spinning the bejeezus out of these things it can't hurt to have a lighter assembly at the RPM.
I'm not normally an aluminum rod guy, but id consider using longer aluminum rods and pistons with a much shorter pin height, Light pins and pistons with some higher end options.
Re: Oil Drain backs
Ah we don't spin em that fast........ LOL
Thank you sir
Thank you sir
Re: Oil Drain backs
EverySparePenny wrote:Ah we don't spin em that fast........ LOL
Thank you sir
8500-9000 for 30 seconds is a lot to ask out of eagle rods and heavy pistons.
Re: Oil Drain backs
dfree383 wrote:EverySparePenny wrote:Ah we don't spin em that fast........ LOL
Thank you sir
Concur, I'm not quite to that rhelm yet, but I hope to be with the new powerplant.
Re: Oil Drain backs
EverySparePenny wrote:dfree383 wrote:EverySparePenny wrote:Ah we don't spin em that fast........ LOL
Thank you sir
I started with Eagle H-beams and went with Oliver billet after having a rod failure at 7500. The 468 in my puller regularily buzzed 8600 with the Oliver's and would go over 9000 when I put the cut bar tires on. Never had a failure and the motor is still going strong today. I must add though that no expense was spared on the motor. You have to have superior parts, machining and an engine builder that knows how to make it live at these levels!
Re: Oil Drain backs
HorsinAround wrote:EverySparePenny wrote:dfree383 wrote:EverySparePenny wrote:Ah we don't spin em that fast........ LOL
Thank you sir
Agreed, got to watch the lower end stuff when you start hitting these levels of abuse, the better rods tend to hold their shape and not distort.
Re: Oil Drain backs
Thank you sir
Was the 468 on a factory crank, out of curiosity?
» Cyl Head oil drain backs ?
» What pan is this?
» checking voltage drain
» Gunk on Oil drain plugs
» A Trick flow heads oil drain
» What pan is this?
Page 3 of 4
