Gunk on Oil drain plugs
Gunk on Oil drain  plugs Empty Gunk on Oil drain plugs
Post  t-bird racer March 8th 2018, 9:05 am
I have this Black, paste like Gunk on the oil drain plug magnets, Its metallic, nothing shinny, nothing course,
almost like a graphite feel. Is this just stuff that the filter isnt picking up? I use the Wix Racing Filters, Maybe
I should switch to the Jomar and see if there is a difference.
Any Ideas.
t-bird racer
t-bird racer
Gunk on Oil drain  plugs Empty Re: Gunk on Oil drain plugs
Post  dfree383 March 8th 2018, 9:14 am
ring and cylinder wall stuff, nothing to worry about
Post  t-bird racer March 8th 2018, 9:56 am
Thanks for the response. I will be trying the jomar filters maybe they will trap more of the stuff.
t-bird racer
t-bird racer
Post  Frank Merkl March 18th 2018, 1:29 pm
it has to get to the oil filter threw the oil pump , more magnets in the pan!
Post  The Mad Porter March 18th 2018, 2:38 pm
As Mr Freelander noted but I would add in addition...
The molybdenum disulfide, zinc and lithium additives found in assembly goop and or paste are paramagnetic. I see this on magnetic drain plugs frequently...
Just a mixture of ring and cylinder wall break in garbage and some or all of the above.
Not to worry.
S
The Mad Porter
The Mad Porter
