Vacuum pump
Vacuum pump Empty Vacuum pump
Post  Tore February 9th 2018, 3:45 pm
Who makes the shortest Vacuum pump to mount on engine plate?
Tks Tore
Tore
Tore
Vacuum pump Empty Re: Vacuum pump
Post  dfree383 February 9th 2018, 4:05 pm
The star one is pretty compact
Post  cool40 February 9th 2018, 8:49 pm
Star is definitely shorter than the Moroso. I have used both but the star is the way to go IMO. I had to bracket the Moroso and go below the motor plate but I do run the short snout crank.
Post  Tore February 9th 2018, 9:51 pm
cool40 wrote:Star is definitely shorter than the Moroso. I have used both but the star is the way to go IMO. I had to bracket the Moroso and go below the motor plate but I do run the short snout crank.
I also have the short snout crank. Which Star pump did you have?
Tore
Tore
Tore
Post  dfree383 February 9th 2018, 10:07 pm
http://www.starvacuumpumps.com/products/STR.03.01.000
Post  cool40 February 9th 2018, 10:16 pm
dfree383 wrote:http://www.starvacuumpumps.com/products/STR.03.01.000
Cool this one. Thanks Dave
Post  Tore February 9th 2018, 10:24 pm
Thanks guys. What did you use for a front driver? Also you got a picture you could post of your set up?
Tks Tore
Tore
Tore
Post  cool40 February 10th 2018, 12:50 am
Vacuum pump Image51
Vacuum pump Image50
These may be upside down idk why I can't post pics on here right. confused
Post  cool40 February 10th 2018, 12:57 am
Vacuum pump Image52Vacuum pump Image54
Post  Tore February 10th 2018, 9:05 am
Thanks for the pictures. Did you buy this as a kit with the drive mandrel?
Tore
Tore
Tore
Post  dfree383 February 10th 2018, 9:40 am
I used Peterson spline drive stuff.
http://www.petersonfluidsys.com/drive-spline-hubs.html
Post  cool40 February 10th 2018, 11:13 am
Tore wrote:Thanks for the pictures. Did you buy this as a kit with the drive mandrel?
Tore
no the mandrel is a modified piece from rons. I got it years ago with a toilet setup and have used it ever since.
Post  Lem Evans February 10th 2018, 11:37 am
dfree383 wrote:I used Peterson spline drive stuff.
He got it from his buddy Lem Laughing
