Pump Gas 521 with power range of 3000-5500
Pump Gas 521 with power range of 3000-5500 Empty Pump Gas 521 with power range of 3000-5500
Post  Straubtech June 13th 2018, 3:32 pm
From Chris Nowack:
A friend and a customer of mine requested some help selecting a mild street cam and roller lifters for his 521 BBF pump gas build with untouched P51 heads and 850 Carb. He wanted to start building torque at 3000 and not rev any more than 5500. He wanted good vacuum for brakes and heater controls and of course boil the tires as long as he had his foot on the pedal. Well I had Chris Straub work his magic on a cam for us. We just got to tune it on the dyno and the results absolutely blew expectations out of the water. The icing on the cake was the fuel economy. We warmed it up, broke it in, and made 11 dyno pulls and used less than 5 gallons of fuel total. Thanks Chris Straub for your help and expertise.
RPM      HP     TQ
3000    300    510
4500             675#/ft Peak
5600    651 Peak
I missed peak by 100 rpm.
Straubtech
hbstang likes this post
Pump Gas 521 with power range of 3000-5500 Empty Re: Pump Gas 521 with power range of 3000-5500
Post  rmcomprandy June 13th 2018, 6:20 pm
Straubtech wrote:From Chris Nowack:
RPM      HP     TQ
3000    300    510
4500             675#/ft Peak
5600    651 Peak
Shure looks like blatant advertising to me ...?
I think simply posting the engine particulars would suffice and forget about the rest.
Post  Straubtech June 15th 2018, 9:53 am
RPM      HP     TQ
3000    300    510
4500             675#/ft Peak
5600    651 Peak
Randy had not gotten permission from the builder when I posted this. I will next time sir. I apologize to you
Camshaft
.700/.688
278/304 .020
250/270 .050
169/175 .200
107 LSA
Pump gas 10 to 1 521 with Kaase P51's out of the box
I would post the dyno sheet but I am not allowed.
Straubtech
Post  rmcomprandy June 15th 2018, 10:05 am
RPM      HP     TQ
3000    300    510
4500             675#/ft Peak
5600    651 Peak
Camshaft
.700/.688
278/304 .020
250/270 .050
169/175 .200
107 LSA
It doesn't really bother way me one way or the other but, I was simply pointing out how it appeared.
I know how it is with customers and their dyno runs ... they all seem to think they have some kind of magic bullet that others just couldn't wait to try and duplicate.
In actuality, what I have found, is that the engine build within someone else' mind is always much better than what has already been tested and accomplished.
Pump Gas 521 with power range of 3000-5500 Empty More info
Post  Axshun May 15th 2020, 8:10 am
Wondering if you could tell me what intake this engine is using? I have the same size cubic inches, heads and performance goals. Looking for a cam, so this post has me very interested, but knowing the intake brand & type would be helpful. The information can be PMd to me if needed.
Thanks in advance!
Axshun
Post  Curt May 20th 2020, 10:25 am
Chris certainly has no problem dislocating his shoulder to pat himself on the back.
