SCJ Head Rocker Boss
SCJ Head Rocker Boss Empty SCJ Head Rocker Boss
Post  wickettoby1 July 22nd 2018, 2:29 pm
Is it common on the SCH heads to have to grind down the rocker stud boss in order to get a socket on a head stud nut for cyl # 4 or 5? Even with a thin wall socket there isnt enough room. It's not currently hitting the pushrod guide plate but it may if i clearance the stud boss. FYI the studs are ARP with a 7/8 nut.
SCJ Head Rocker Boss 15322810
wickettoby1
SCJ Head Rocker Boss Empty Re: SCJ Head Rocker Boss
Post  Lem Evans July 22nd 2018, 2:32 pm
I use a kit with the smaller 12 point nuts.
Post  wickettoby1 July 22nd 2018, 2:34 pm
I guess that's one option. I never had an issue with the previous Dove heads but it's apples and oranges.
wickettoby1
Post  rmcomprandy July 22nd 2018, 4:40 pm
wickettoby1 wrote:Is it common on the SCH heads to have to grind down the rocker stud boss in order to get a socket on a head stud nut for cyl # 4 or 5? Even with a thin wall socket there isnt enough room. It's not currently hitting the pushrod guide plate but it may if i clearance the stud boss. FYI the studs are ARP with a 7/8 nut.
Not an issue when you use 12 point nuts.
EDIT: I should have read the whole thread before answering.
Post  duff429 July 22nd 2018, 6:02 pm
I bought the arp 155-3603. Wonder if I will run into the same issue
duff429
duff429
Post  The Mad Porter July 22nd 2018, 8:35 pm
duff429 wrote:I bought the arp 155-3603. Wonder if I will run into the same issue
Not likely. That ARP bolt kit has a 5/8" hex.
S
The Mad Porter
The Mad Porter
