Milodon Street and Strip Oil Pans 30929 How much Oil
I have a 460 with a Milodon 8 quart front sump pan and a windage tray. First word of caution, when installing a windage tray be sure the dipstick will work with it or drill a hole to accomodate it BEFORE putting the engine back together and into the car.
Anyway, should I run the full 8 quarts of oil with this pan? I'd think 6 might be adequate and low enough to cut down on windage. I don't go past 6400 RPM.
Thanks!
Thanks!
Ol Yaller 73- Posts : 3
Re: Milodon Street and Strip Oil Pans 30929 How much Oil
I fill mine mid-way on the add / full mark on the dipstick. I have around 2 liters leftover from 2, five liter jugs.
One liter is just slightly less than a us quart. I'm guessing around around 7-7 1/2 us quarts.
rmk57- Posts : 176
Personally, I would use the minimum amount of oil in the pan to still not have any problems ... finding that point won't be easy.
» locked timing on street/strip
» F3TE/EFI street/strip builds?
» Looking for a street/strip fox body oil pan
» Solid Roller for Street/Strip duty ???
» Moroso street/strip oil pan questions
