429 Cobra Jet carburetors
429 Cobra Jet carburetors Empty 429 Cobra Jet carburetors
Post  gcj June 17th 2019, 9:06 pm
Hi everyone:
I have a slightly modified CJ 466 that I have used the std. Quadrajet intake on. I have used the  Q-jet 7040288 on this engine and it works fine, like stock should do.
I have been looking at the old Holley 6211 / 6212 / 6213 made for some Q-jet replacement OEM on brand X products back in the 70´s - as a potential replacement for the Q-jet. Anyone done this in the past? Did it work well for the Ford?
I used the 6213 on my big block Cowl Induction X back in the day and found it to work very well. These Holley carbs come up for sale every so often so I was wondering if an 800 cfm double pumper might be interesting on the Cobra Jet.
Holley made a kit to convert 4160 carbs to Ford A/T kickdown setup. Does anyone know if this is still available from Holley, then for a 4165 ?
Reason: I want to retain stock manifold and fuel system height, anything else will not clear the hood on my Spoiler.
G.
429 Cobra Jet carburetors 412033277
gcj
429 Cobra Jet carburetors Empty Re: 429 Cobra Jet carburetors
Post  glenevans June 17th 2019, 10:23 pm
Nice car!
glenevans
Post  t-bird racer June 18th 2019, 8:36 am
I think you should just give up!
I'll take that car off your hands and your frustrations will be over.
t-bird racer
t-bird racer
Post  rmcomprandy June 18th 2019, 9:34 am
gcj wrote:Hi everyone:
G.
That should not be a problem unless you need the transmission linkage on the carb..
Post  gt350hr June 18th 2019, 12:04 pm
The kit will not work with the 800 as it is a double pumper and the kickdown linkage interferes with the carb linkage.
gt350hr
