Looking for advice on getting my 66 Fairlane into the 5's
+10
airford1
pmrphil
jpierce55
66Fairlane-OldGlory
14 posters
Looking for advice on getting my 66 Fairlane into the 5's Empty Looking for advice on getting my 66 Fairlane into the 5's
Post  66Fairlane-OldGlory October 25th 2019, 2:05 pm
My dad and I just finished putting together our 66 Fairlane. We were able to put about 7 passes on it this fall and our fastest et was 6.37 in the 1/8. 1.40 60'. 108mph. The car is back halved and we run 32x14 goodyears (probably going to 31x10.5w next Spring). The motor is a 514 (filled block) with aluminum cobra jet heads that have flow around 380/240 (yes the clipping issue has been fixed). Ford Motorsports Dominator Intake that has been cleaned up and port matched to heads. 1050 dominator carb. Q16 fuel 0.683 lift cam, cam advertised duration: In.298, Ex. 302, cam duration at 0.050: In. 262, Ex.267. 1.8 rockers. Has not been dyno'd but would estimate somewhere around 675-725hp. Rollerized C6. We have 5.14 gears in the rear. Car weighs 3300 w/ driver. Ladder bar car with strange DA's in the rear.
SO... We want to get into the 5.9x's. Would this be possible by building a 557 short block and putting our top end on it? Long term we would like to build a 572 or 598 but that would quickly get expensive and is not practical for this winter. I know there are better heads out there but would rather not buy new heads yet. What do you all think is the best route to go to get into the 5.9x's. Thanks in advance.
Last edited by 66Fairlane-OldGlory on October 25th 2019, 4:27 pm; edited 2 times in total
66Fairlane-OldGlory
66Fairlane-OldGlory
Looking for advice on getting my 66 Fairlane into the 5's Empty Re: Looking for advice on getting my 66 Fairlane into the 5's
Post  jpierce55 October 25th 2019, 3:44 pm
The cam duration and intake type would help people advise you.
jpierce55
Post  BBFTorino October 25th 2019, 4:08 pm
Nitrous Oxide!!
Post  66Fairlane-OldGlory October 25th 2019, 4:28 pm
jpierce55 wrote:The cam duration and intake type would help people advise you.
Updated original post. Thanks!
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  pmrphil October 25th 2019, 5:55 pm
Put it on a diet - weight savings alone will make it faster
pmrphil
Looking for advice on getting my 66 Fairlane into the 5's Empty fairlane
Post  hbstang October 25th 2019, 7:55 pm
to get your car to run 5.95 in the 1/8,you would need about 800 hp.your not going to get 150 hp with 43 cubic inches.my guess would be p-51 on your short block with more cam.that would be closer for sure.you would have to do the valve pockets on the pistons,but that can be done with the tool on the short block.maybe the trick flow 325 heads may do it.just my view.
Post  airford1 October 25th 2019, 11:47 pm
Call ACME
airford1
airford1
Post  Dave De October 26th 2019, 12:14 am
All the numbers look low performing to get into the 5's the 60 needs to be in the low to mid 1.30's The gear ratio looks to big. I assume the compression is up around 14 with the fuel that you are running. The converter should be higher than 5,000 rpm. Where are you shifting and how high is it running when you cross the line?
Post  stanger68 October 26th 2019, 12:59 am
Where you located? I have a pair of MT 33/10.5W I may be willing to swap for those 32/14 if they’re not worn out.
Post  66Fairlane-OldGlory October 27th 2019, 11:06 am
What are your all’s thoughts on this idea. Build a 598 shortblock and use my cam, heads, intake, etc and maybe go to an 1150 or 1250 carb. I know my heads would be the bottleneck but next winter I would then upgrade the heads, cam, etc to really wake the 598 up. Dumb idea to run my heads on a 598 shortblock for a season?
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  cool40 October 27th 2019, 11:31 am
I think you have something to gain with what you have. Different cam and probably converter imo. A torque converter can mean everything. Best thing I did was put a msd grid on mine to see what was going on during the run. Racepak is ideal but kinda pricey.
Post  Dave De October 27th 2019, 5:32 pm
I agree with Cool40.
Back when I had a 547 with FMS SCJ heads they flowed similar to yours and the car got solidly into the 5.90's with a little more cam duration shifting at 6400 running E85 with an 1150 dominator. I did this with a non-rollerized C6, 4500 stall and a 4.11 gear for 9.40's in the 1/4 at 3250# with 32" tall tires.
Big differences with our packages here are probably gearing, cam, and converter. Even if I set mine up for the 1/8th I dont think the gear would be anywhere close to 5.14 with my converter that slips above 12% with synthetic fluid.
Every time I lowered the gear ratio number the car seems to hold the 60ft, the 1/8th got slightly better and bigger gains at back half et and MPH
And your converter stall is?
Your shift rpm and trap rpm?
Are you at high elevation?
Post  rmcomprandy October 27th 2019, 5:49 pm
What lind of exhaust system is on it ...?
With a correct converter and leaving in 2nd speed you should be there at 3,300 lbs. I'd bet it is actually heavier.
Post  66Fairlane-OldGlory October 27th 2019, 6:40 pm
Dave De wrote:I agree with Cool40.
Currently have a 9" art carr 4500 stall
Shifting at 6200
We are in Missouri
I have a 4.30 gear for the car that I could go back to. Also I've been thinking about getting an 1150, do you think id pick up a tenth just by switching to the 1150? Thanks for the feedback!
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  66Fairlane-OldGlory October 27th 2019, 6:42 pm
rmcomprandy wrote:What lind of exhaust system is on it ...?
2" Crites headers. Currently have an art carr 9" 4500 stall.. We scaled the car a couple months ago and its actually closer to 3200 with driver
Last edited by 66Fairlane-OldGlory on October 27th 2019, 6:52 pm; edited 1 time in total
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  66Fairlane-OldGlory October 27th 2019, 6:44 pm
cool40 wrote:I think you have something to gain with what you have. Different cam and probably converter imo. A torque converter can mean everything. Best thing I did was put a msd grid on mine to see what was going on during the run. Racepak is ideal but kinda pricey.
Thanks for the feedback! Going to a .723 cam has crossed my mind, wonder what I'd gain by going that route. I'm running an art carr 9" 4500 stall currently. I'm open to recommendations if you think this converter is holding me up
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  Lem Evans October 27th 2019, 6:59 pm
More duration and lift will pick it up for sure.
Post  66Fairlane-OldGlory October 27th 2019, 7:03 pm
Lem Evans wrote:More duration and lift will pick it up for sure.
What would you recommend? Thanks for your feedback
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  Lem Evans October 28th 2019, 9:17 am
How much lift will your springs allow?
More cam will not help much until you change the converter.
Post  Dave De October 28th 2019, 9:31 am
If you can get that 514 to live large at 7,000 rpm 5.90's are gonna happen.
Lem has the recipe for that to happen.
Post  66Fairlane-OldGlory October 28th 2019, 5:24 pm
I would probably just have to get new springs to work with more lift. Which is fine with me. Who would you recommend me to go to for a new converter?
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  66Fairlane-OldGlory October 28th 2019, 9:11 pm
PM Sent
66Fairlane-OldGlory
66Fairlane-OldGlory
Post  cool40 October 29th 2019, 12:53 am
With c6 and that gear the car should leave pretty hard if the converter is what you said, even @3200#. 60’ don’t equate to leaving hard imo. I assumed you leaving off the foot brake? The other thing is only shifting @6200 tells me converter is tight or motor is lazy or it would be out of steam in high gear pretty early. The 3 speed is more forgiving of a tight converter but still is a deal breaker if it’s out in left field. What rpm does it cross at in high gear?
Post  jbozzelle October 30th 2019, 11:25 am
Get a cam custom ground for it.  More duration and lift and a good amount more duration on the exhaust will get it there.  And get that converter up in the 54-5500 area on the leave.
I spun my stock block, cast crank 514 to 7200 regularly so your's should be able to take it too...
Are you shifting all gears through the 1/8th? What's it cross the line at? In what gear?
Post  738drvr October 30th 2019, 10:55 pm
.4 is a lot. 108 mph won’t cut it. You’re not making the power you need to for that weight. I agree with others here. Put it on a diet and pick up as much power as you can. Once that’s done THEN change the converter. 5’s at 3300# needs a lot of hp. Ask me how I know.
