D1ve block and cj caps
Found a block local to me that has had the cj caps done to a dive block, supposed to have all machine work completed , looking at doing 4.5 stroke build , with 250 shot on top, on methanol, I know tune with NX is a big factor, and yes any thing can break, am I pushing the limits of the factory block here , I have read a ton on blocks and it looks I'm o the edge for what I'm asking for
Steve-oh- Posts : 59
Re: D1ve block and cj caps
The fact that you’re even questioning it means that you already know that a stock block is a not gonna be suggested for this application. Even if you can get a stock block to hold together you’ll have zero room to grow and zero room for error.
wickettoby1- Posts : 352
How much HP & RPM? By the way, here is what a standard-webbed block looks like when machined for non-register, flat-bottomed caps a la OEM SCJ:Steve-oh wrote:Found a block local to me that has had the cj caps done to a dive block, supposed to have all machine work completed , looking at doing 4.5 stroke build , with 250 shot on top, on methanol, I know tune with NX is a big factor, and yes any thing can break, am I pushing the limits of the factory block here , I have read a ton on blocks and it looks I'm o the edge for what I'm asking for
Like to see around 850 on just engine and no more than 7 on rpms
» D1ve vs Dove block with 4 bolt caps????
» i have a d1ve block ,thinkin of doin 4bolt main conversion using miloden caps , is it worth it ,im on a budget
» How much does it cost to get 4bolt caps get put on?(roughly) and what can my 77 460 block with center 4bolt caps block handle?
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
