i have a d1ve block ,thinkin of doin 4bolt main conversion using miloden caps , is it worth it ,im on a budget
+8
drummond race cars
powerstrokeace
5pointslow
12 posters
wanted to do 4bolt main cap conversion on my d1ve block
im on a budget lookin to do a 800-850hp at flywheel
prob gonna use nitrous
but lookin at doin 4bolt main and doin a partial fill of hardblock to bottom of water pump holes
and aybe a valley girdle
i know a A-460 block is ideal , but im not loaded
thanks , any input will be appreciated
this is gonna be a race motor for my mustang track only
5pointslow- Posts : 1408
Re: i have a d1ve block ,thinkin of doin 4bolt main conversion using miloden caps , is it worth it ,im on a budget
Didn't you recently post a question just like this...?
Just my oppinion:
Forget the valley girdle unless you simply like to spend money for ficticious reasons.
Fill the block half way.
Use some main cap straps on the mains with studs.
Just my oppinion:
posted a thing about cost of of getting caps done
what can these blocks handle with 4 bolt center caps and a partial fill ? any ideas?
I've been using a 2 bolt block pushing a little over 800 for 9 years. 1900lb dragster though.
Ace
Ace
powerstrokeace- Posts : 1496
With 4 bolt caps and a fill probably 850 hp reliably and more with less service life IMO. But thats with a conservitive tune and a good maintence routine. Plus alot depends on the other parts you use too, something like poping the head off a cheap valve or not maintaining valves springs, not keeping up with roller lifters, Etc. will end the life of a block just as easy as overpowering it.
iv used the pro gram caps on a few and have had very good luck , one was well over 1000 hp with nitrous.
buy an A460 block from BF Evans Raceparts !!!! .it will save you money in the long run
x2,and did you check out the thread over in the bar&grill with the nice pic's of a build like your thinken about?caps on a d0ve block would be a good start if you cant swing the A460 now.bruno wrote:buy an A460 block from BF Evans Raceparts !!!! .it will save you money in the long run
If you haven't looked at this thread, take a look. It might change your mind about the D1VE block...:
https://www.429-460.com/general-discussion-f5/the-552-carnage-pictures-i-promised-t6565.htm
Nevs- BBF CONTRIBUTOR
The A460 block is an investment........glad I made mine years ago.
Nevs wrote:If you haven't looked at this thread, take a look. It might change your mind about the D1VE block...:
While that's a very bad and costly problem, how much of that could have been avoided by not using the 4.5 stoke crank and using a 4.3 stroke? I've always heard that you want to avoid the 4.5 crank in a D1 block and it's better suited to a D9 block since it has the longer cylinder skirts. Obviously not saying an a460 block wouldn't have been the better choice, just want to learn something.
kjett- Posts : 1169
Ask Paul Kane,
Im sure he will probably chime in here. Hes pushed a ton of stock parts. He WILL know.
72mav- Posts : 1081
If you have the money to build it twice, you have the money to build the correct way once.
Outlaw5.0- Posts : 122
Outlaw5.0 wrote:If you have the money to build it twice, you have the money to build the correct way once.
X2!
Nevs wrote:Outlaw5.0 wrote:If you have the money to build it twice, you have the money to build the correct way once.
X2!
X3 your looking for 800-850 + spray.... you need to step up and get a good block, it will pay for itself.
» D1ve block and cj caps
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» How much does it cost to get 4bolt caps get put on?(roughly) and what can my 77 460 block with center 4bolt caps block handle?
» 4bolt main caps
» Question about Milodon 4bolt main caps
» 4bolt main caps
