C-6 1st gear issue
C-6 1st gear issue
Other than linkage/cable adjustment, what else would cause loss of 1st gear? Manual forward pattern VB, feels like starting off in 2nd with shifter in 1st. Can tell no difference on 1-2 shift, 2-3 is crisp/hard shift. No slippage anywhere as far as I can tell. Fluid looks clean, smells fine. I need to double check cable adjustment but was working fine. Did a test hit and shook the tires pretty hard before I noticed the issue, hope I didn't already break the trans.
Sheldon G
Sheldon G
STR-LGL-70- Posts : 223
Re: C-6 1st gear issue
Who's valve body ?
Do a fluid psi check
How good is reverse ?
whitefield- Posts : 2244
I'd be having a real good look at shifter . For 10st gear is the forward clutch and low clutch or one-way. Since 2nd is good you know the forward is ok. Pretty rare for a one-way or low clutch failure
If it is a cable shifter good chance it's not pulling right back.
Is the lever attached to the selector shaft so it moves in an even arc each way ?
Gregaust- Posts : 625
Couldn't the band be gone and it's going first to third?
Last edited by norm on November 30th 2020, 8:41 pm; edited 1 time in total (Reason for editing : tant thpell)
norm- Posts : 261
Thanks for the replies.
I'm not sure who made the VB, if I had to guess it would be JW as the trans had a JW converter with it when I bought it. Has Hurst 1/4 stick shifter.
I'm thinking it may just be a cable adjustment but I haven't had time to dig into it yet.
Reverse is fine, 2 to 3 shift is good, no slippage as far as I can tell. I need to get a gauge to check line pressure if for no other reason to keep an eye on things, what pressure range is acceptable?
Thanks, Sheldon G.
Thanks, Sheldon G.
Disconnect the cable from the trans and put the shifter in the low position with cable disconnected and make sure you can manually put the trans in low by hand. Adjust cable in low. I've heard of interference fit in low with some cars and a C6 trans. Lots of early cars had FMX's and C4's instead of C6's. C6's are actually quite easy to rebuild. I always hated messing with the VB on these trans the most but with the VB removed they are very easy to air check. I ran a trans brake VB for years in a C6 and I never hit the tree as consistently with a glide as I did with the C6. The C6 wasn't as consistent though.
The stock VB would engage by gear
trans manually in low - Forward Clutch, Reverse Clutch and over running clutch (sprag) holding
trans in second intermediate band applied and forward clutch
high gear forward clutch and direct clutch
Sprag is a possible failure here too and the early C6 Sprags were not lubricated. no oil holes
n5ifi- Posts : 6
» C6 3rd gear shift issue
» TCI Manual Without a brake-3rd Gear Flare Fixed But Now 2nd Gear Flares. Frank Merkel please help?
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» 29x10.5 w tire ,1.80 first gear glide, nitrous , wanting 6800-7000rpm thru traps ...what gear roughly???
» Pro Stock Trans gear ratio / Rear Gear
