Front end swap on my 1969 F100
Page 1 of 3 • 1, 2, 3
BigBlockRanger likes this post
Re: Front end swap on my 1969 F100
wickettoby1- Posts : 352
BigBlockRanger- Posts : 1260
cool40 and Mark Miller like this post
I seen a couple of them done that way I don't want to cut my bed of the truck up like they do plus they have to cut the cab to make it fit. I am not looking to make a bumper drag effect I just like to drop it a couple of inches
We bolted a flat piece of steel to the CV pedestals, then trimmed the towers until they fit correctly, then welded them to the flat plates. Done. The driver's side later needed a small notch to clear the steering shaft properly.
![Front end swap on my 1969 F100 20161011](https://i.servimg.com/u/f81/20/23/76/03/20161011.jpg)
Here are a few pics so far
BigBlockRanger and Mark Miller like this post
QtrWarrior likes this post
![Front end swap on my 1969 F100 Img_2024](https://i.servimg.com/u/f91/19/97/17/70/img_2024.jpg)
![Front end swap on my 1969 F100 Img_2025](https://i.servimg.com/u/f91/19/97/17/70/img_2025.jpg)
![Front end swap on my 1969 F100 Img_2035](https://i.servimg.com/u/f91/19/97/17/70/img_2035.jpg)
Got the engine back in started mocking up the power steering pump pulled the pulley off then pulled the pulley off the pump from the truck. It will not work on the 08 pump shaft was to small so started digging through some pumps my buddy has. I found one that would work so I ordered a new pump should have it Monday. Plus had to buy a new dizzy the shaft bushings are worn out. I didn't notice it when I pulled it out. When I installed it I noticed the shaft would move if I retard the dizzy and the star would hit the pick up. I don't know how the truck was running as good as it was before I put the engine. So I will try to fire it up next week sometime after I get the pump and dizzy installed.
» Front Coil Springs for 62 Galaxie with a 460 swap
» 1969 429 Boss Making a Pass Video 1969 Vintage
» 1969 Lincoln Mk III
