New Trans install with mid plate Help.
So the last few years I've been plagued with stripped flex plate teeth. I believe the issue may have been caused by stripped starter bolt hole threads and the starter was pushing away from the bell housing. My transmission ( Glide) was due to be serviced so I upgraded to a Reid Case, and new Reid Bell Housing, Meziere Billet Flex plate, and Meziere Starter. While its out I'm checking all the other components.
I have a .095 steel mid plate, and I also had the original block plate. So here's the question. Should I only have the mid plate and leave the original "block" plate out? This set up also used an adapter bushing in crankshaft.
I'm just try eliminate all the problems.
Any and all help is appreciated.
Rich
Rich
t-bird racer- Posts : 193
Re: New Trans install with mid plate Help.
If the midplate is cut nice to locate the starter as the steel block plate usually does , There is no real reason to use the steel plate
Gregaust- Posts : 626
» Motor plate install basics... tutorial video maybe???
» 460 block to trans separation plate.
» 429/460 auto trans Block Plate/spacer
» Does adding a wave plate help the forward drum last after trans brake installation
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
