FMS A460 heads Testing to see if there is any interest
Fixing to replace my FMS heads with a new set of 18 bolts with shaft mounts.
I have flow numbers for the heads. 2.40 Titanium intakes 1.90 SS exhaust, new 1.80 Comp Ultra Pro Magnum with poly locs, lifters, Jomar Stud Girdles
May sell the intake??? Depending on my ability to get a replacement.
Was in a 2700# Big tired 572ci that ran best 5.26 @130 3200' you can use your own calculators to figure out HP.
PM or DM(whatever that is) for more info.
Bryan
Bryan
Movemonger- Posts : 7
» question on compression ...using pump gas (a460...using fms a460 heads)
» Cometic MLS head gaskets
» Question about TFS A460 and Motorsport A460 heads
» BBF PARTS - B460 Heads, A460 HEADS - MUCH MORE
