how much power to run 6.0 1/8th mile
+6
5pointslow
fordmonsta
10 posters
how much power to run 6.0 1/8th mile Empty how much power to run 6.0 1/8th mile
Post  fordmonsta October 3rd 2022, 9:28 pm
bought a 68 cougar drag car from a friend a month or so ago, with me in it it weighs 3170, thats with a 351w and c4, its all round tube strut front, 4 link rear. how much power would it take to run 6.0-5.90 with a big block? it'll have a glide in it also. thinking a low maintnance bracket motor 532 cube would be my ideal situation.
fordmonsta
how much power to run 6.0 1/8th mile Empty Re: how much power to run 6.0 1/8th mile
Post  supervel45 October 3rd 2022, 9:59 pm
A Lot. Here is what 650 Dyno proven HP did in a much lighter car for reference. You are likely going to be in solid roller cam big heavy valve spring territory, hence keeping up with the valve train.
https://www.429-460.com/t24243p50-fairmont-472-eddy-head-649hp-index-car-9-77-132mph-10-31-18-added-videos
Your easiest path in my opinion and with the parts shortage is to go with SR-71's. The TFS A heads are back ordered along with the P-51's and the TFS 325's and the AFR's
Put a big solid roller with the Sr-71's and a Mafia with a Dominator and a good dose of compression.
If you go with a factory block because you can't get a A460 ect. you will likely have to go from the 2.37" intake valves to 2.30" depending on your bore size.
http://wallaceracing.com/et-hp-mph-8th.php
You can crunch some numbers in here for what it worth. 750-800
Dave De and 650jetmech like this post
Post  stanger68 October 4th 2022, 8:19 am
My car is a few hundred pounds lighter. Based on my time slips and dyno sheets I would guess somewhere around 800. There are formulas for this calculation.
how much power to run 6.0 1/8th mile Empty try this
Post  hbstang October 4th 2022, 9:47 am
entertainment value only! Very Happy
http://www.wallaceracing.com/et-hp-mph.php
Post  5pointslow October 4th 2022, 10:34 am
I have gone 6.13 in fall air in the northeast
650hp
2920 with driver
summer heat it will go 6.30
5pointslow
5pointslow
QtrWarrior, Mark Miller, nedceifus and 650jetmech like this post
Post  Dave De October 4th 2022, 5:13 pm
Dont get hung up on the calculator. It's at sea level or a DA of zero. In 2,000 foot air at that weight you will need about 850 hp. I'm not convinced that a glide is best at that weight and power.
Post  rmcomprandy October 4th 2022, 9:26 pm
fordmonsta wrote:bought a 68 cougar drag car from a friend a month or so ago, with me in it it weighs 3170, thats with a 351w and c4, its all round tube strut front, 4 link rear. how much power would it take to run 6.0-5.90 with a big block? it'll have a glide in it also. thinking a low maintnance bracket motor 532 cube would be my ideal situation.
A lot will depend upon "how good is the car"
A decent NHRA Super Stock car weighing 2,800 lbs. will go 5.90 all day long with only 650 horsepower.
Less of a car will need more power.
Post  rmcomprandy October 4th 2022, 9:27 pm
double post
Post  dfree383 October 4th 2022, 11:13 pm
About 800 will get you their
Still in stock Block and regular head territory and don’t need super big buck stuff will get you their
Post  fordmonsta October 5th 2022, 11:16 am
Car is all round tube mild steel with 4 link rear and strut front.
url=https://servimg.com/view/20455174/1]how much power to run 6.0 1/8th mile 20220910[/url]
how much power to run 6.0 1/8th mile 20220910how much power to run 6.0 1/8th mile 20220910how much power to run 6.0 1/8th mile 20220910
fordmonsta
Mark Miller and nedceifus like this post
Post  5pointslow October 5th 2022, 12:04 pm
id love to own that car
5pointslow
5pointslow
Post  nedceifus October 5th 2022, 2:21 pm
Sweet ride!
nedceifus
nedceifus
Post  rmcomprandy October 5th 2022, 3:25 pm
Lots of drag cars have all the right equipment to go fast.
The set-up and doing the right things to make the chassis work correctly is the major issue most of the time.
dfree383 and Mark Miller like this post
Post  stanger68 October 6th 2022, 8:33 am
3170 sounds kinda heavy for that car. Especially with a small block. They must’ve left a lot of factory sheet metal when converting to tube chassis. Does it still have factory floors, trunk or something?
Post  fordmonsta October 6th 2022, 10:13 am
stanger68 wrote:3170 sounds kinda heavy for that car. Especially with a small block. They must’ve left a lot of factory sheet metal when converting to tube chassis. Does it still have factory floors, trunk or something?
It's all steel except the hood. It does have nice aluminum tin work throughout. The guy I bought it from said he thought he remembered it weighing 2950 or thereabouts. I'm 250 so I'm just going on what he said. I'll weigh it myself to be sure.
fordmonsta
Post  supervel45 October 6th 2022, 12:30 pm
So 3,300-3,350 with a BB? I guessed 3,300 on the Wallace for 755. 800 to 850 would be a safer bet I think.
https://www.motortrend.com/how-to/0906phr-big-block-ford-engine/amp/
This ones close. I think with the SR-71's you would be there. You can see how much cam they had to put to get all most 800HP. They could have raised the compression also to make up some of the difference.
Post  BB94STANG October 6th 2022, 2:41 pm
3100 lb. Foxbody Mustang has run 6.01 @ 114mph
740HP on the dyno with a glide and 4.11 rear gear.
BB94STANG
BB94STANG
fordmonsta likes this post
