Common Truck Jeep and 4 Wheel Drive Differential Carrier Pad Height
Aka 4.10 and Down or 4.56 and Up Ect. Measurment of Pad Height.
If You Run Across a Unknown Posi/Locker/Open Ect. Carrier and are Trying to Determine What Gear Ratio It Will Work With.
On The 9" Ford 2.72 and Down and 3.25 and Up are The Common Theme with The Eaton Detroit Lockers.
The Newish SL Lockers Show 3.25 and Up Now, Old Was No Lower Then 2.72.
https://www.differentials.com/technical-help-2/carrier-breaks/
^ The Above Chart is Rare and Very Hard to Find. I Looked High and Lo and This Is The Only One I have Ever Found
supervel45- Posts : 4498
MHD Master Housing Dimension Most Common Differentials (Pinion Depth)
Good Article MHD's at End
https://automotivetechinfo.com/wp-content/uploads/2014/10/torque-benders-2-detailed-proecdures.pdf
» Nitrous on a stock longblock
» Ken Block Video ; 65 Mustang all wheel drive
» The new 2011 F-150 5.0 engine tow test drive (and rear wheel dyno numbers)
» Dually wheel extenders in a Pullin Truck
» 4x4 puller truck final drive ?
