Camshaft Identity?
Camshaft Identity?
I've had this cam kicking around on the shelf for 20+ years. Pulled it out of a high school class project-built 460 engine that had been sitting 20 years before I got it. Was rebuilt then stored in the teachers garage and never used.
The cam is a hydraulic flat tappet. Measuring the lift with a set of jive dial calipers, I come up with roughly .458/.493.
The only marking visible is "MAP" stamped on the back of the cam and a few paint markings.
I'm sure it's a small stock-type rebuilder cam but was curious if you guys may have an idea of what it is.
If we could ID it, I was thinking it could be a candidate for the Gas Mileage 460 build.
Thanks!
Thanks!
1EFF100- Posts : 265
Re: Camshaft Identity?
Get out your degree wheel and map it out !
Now why would I do that, when I can be lazy and ask you guys? I would have to dig out one of my core engines, put it up on an engine stand and blah blah blah, way too much work. Come on, Dave, get real. lol. JUST KIDDING!dfree383 wrote:Get out your degree wheel and map it out !
I may end up doing that. But in the meantime, maybe someone has an answer.
dfree383 likes this post
1EFF100 wrote:Now why would I do that, when I can be lazy and ask you guys? I would have to dig out one of my core engines, put it up on an engine stand and blah blah blah, way too much work. Come on, Dave, get real. lol. JUST KIDDING!dfree383 wrote:Get out your degree wheel and map it out !
Or get luck and find someone with a cam doctor?
1EFF100 likes this post
I have a NIB melling? Make make me an offer if you're interested….. it’s not expensive
204
214
.484
.510
On a 112
Also have another one Randy had ground for me it’s a Lunati custom deal
220
220
.536
.540
On a 111
204
214
.484
.510
On a 112
220
220
.536
.540
On a 111
dfree383 wrote:I have a NIB melling? Make make me an offer if you're interested….. it’s not expensive
204
214
.484
.510
On a 112
220
220
.536
.540
On a 111
Ahh, the ubiquitous 204/214 cam that's been around since the beginning of time. lol.
The 220 one is too big for what I need.
Thanks for the offer, Dave. I'll keep it in mind.
I'm actually still searching for the cam that Randy suggested in my other thread.
1EFF100 wrote:dfree383 wrote:I have a NIB melling? Make make me an offer if you're interested….. it’s not expensive
204
214
.484
.510
On a 112
220
220
.536
.540
On a 111
If you can not find the correct ELGIN camshaft, the Howard's that you found would probably be a decent alternative.
Though, It would need to be advance more that how it is ground.
A timing set with a 9 position crank gear would make this an easy thing.
Mark Miller and 1EFF100 like this post
» 521 camshaft
» New Camshaft?
» camshaft
» Needing advise on a 598ci street friendly drag radial Foxbody on pump gas
» camshaft identification
» New Camshaft?
» camshaft
