I want to get my engine dyno'd
+10
Big block fox 339
D. Sea
jones
14 posters
I want to get my engine dyno'd Empty I want to get my engine dyno'd
Post  jones January 7th 2010, 12:54 am
I have talked with Charlie, Mike and Phillip but it has been some times now. When would be a good time to look into doing this?
I have a couple of simple questions.
1. Besides a complete long block, intake and distrubitor what other parts would I need?
2. Tool, I know I will need to bring my own timing gun.
3. Ignition box and coil?
4. Fuel system?
Patrick over at Prosystems suggest if I decide to go with his sv-1 carb that I get it before the dyno test. Where Phillip as offered to bring one or two carbs and tune them to the engine on the dyno.
I'd like to try a 4500 intake manifold and 2" to 2-1/4" headers. Would really like to try a solid roller setup but I don't know how it could be done.
Link to Engine build thread. https://www.429-460.com/proven-builds-f4/i-finally-got-my-528cu-engine-finished-t2817.htm
jones
I want to get my engine dyno'd Empty Re: I want to get my engine dyno'd
Post  jones January 7th 2010, 2:49 am
Lets see if we can get this party going!!! We can have a dyno party and I'll bring the dyno queen. Just let me know?
jones
Post  bruno January 7th 2010, 7:59 am
cool deal Josh ..... if you need anything let me know ...my victor is getting finished up at Induction-Solutions let me know if you need to borrow it along w/ my 1250 QF ....then you can spray it on the dyno Wink
http://WWW.CKRME.COM
Post  dfree383 January 7th 2010, 8:02 am
I got some 2" Dyno Headers you can borrow.
Let me know when you'll be hitting it and I see about stopping by.
Post  bbf-falcon January 7th 2010, 8:36 am
Hope it all comes together Jonesy. Good luck Buddy. I have a set of 2" Chassis headers if you can use them for the Dyno.
Post  jones January 7th 2010, 10:43 am
Bruno, I doubt my engine will support a 600 shot but that would be a fun dyno event!
jones
Post  jones January 7th 2010, 10:47 am
dfree383 wrote:I got some 2" Dyno Headers you can borrow.
That would be great!
jones
Post  Lem Evans January 7th 2010, 11:09 am
You don't need a ign. box....coil and t. light would be optional .
Post  schmitty January 7th 2010, 11:16 am
I've got a Saturday Night Special Lem grind roller cam if you'd like to give one a whirl. Twisted Evil I don't have an extra set of lifters though. Cool I learned a lot of good info when I did mine, and was glad everything was spot on when it was done.
Post  jones January 7th 2010, 11:27 am
Lem Evans wrote:You don't need a ign. box....coil and t. light would be optional .
Would you have a way to run the water pump or should I try to setup a pulley setup? How much of the fuel system is needed? I am using a by-pass regulator and electric fuel pump.
jones
Post  jones January 7th 2010, 11:30 am
schmitty wrote:I've got a Saturday Night Special Lem grind roller cam if you'd like to give one a whirl. Twisted Evil I don't have an extra set of lifters though. Cool I learned a lot of good info when I did mine, and was glad everything was spot on when it was done.
The hardest part about swapping to a solid roller is almost everything would have to change. Pushrods, valvesprings, lifters. Where if I was already using a roller setup it would just be a camshaft and valvespring swap.
jones
Post  Lem Evans January 7th 2010, 11:32 am
Use Mike's pump and reg. You can use the motor and belt thing that can be seen on the 502 truck engine .
Post  jones January 7th 2010, 11:39 am
Lem Evans wrote:Use Mike's pump and reg. You can use the motor and belt thing that can be seen on the 502 truck engine .
That's what I thought I had read, just making sure!
jones
Post  jones January 7th 2010, 11:44 am
PS. Lem, would you mind if you was the bank for my "jones Dyno Fund"? Anyone that cares to donate towards the dyno fees or needed parts.
I'll need to scrap togather some money for a carb or else just bring my old 850 dp.
jones
Post  Lem Evans January 7th 2010, 11:46 am
Yea...I got your 15 cents and a 1150 you can try.
Post  jones January 7th 2010, 11:52 am
Lem Evans wrote:Yea...I got your 15 cents and a 1150 you can try.
Thanks,
Anyone got mikes number? Or should I talk to Uncle Charlie since he got me threatened! Laughing uhmmm Suspect anyway Laughing
jones
Post  Lem Evans January 7th 2010, 11:52 am
270-729-5556
Post  jones January 7th 2010, 12:00 pm
Lem Evans wrote:270-729-5556
He's on vacation til the 18th. I guess that gives everybody pleanty of time to send their funds in.
jones
Post  dfree383 January 7th 2010, 12:41 pm
I also have a "Few" Carbs laying around......... Just figure out what you want to try.
Set up a plan and try not to include eveything in the world. Timing Loops, Carb Swaps and Tuning and Maybe Some Header changes are typical pretty productive things to get done in a short time.
Post  jones January 7th 2010, 12:59 pm
Break engine in if I hadn't all ready. Then first pull would be using the J429 intake with adapter plate to fit a 1100 dominator. Then try a single plane 4500 intake with the same carb. Adjust valve lash some. Maybe play with cam timing if the numbers appear to be way off. maybe try bigger or smaller carbs, just depend on what the carb folks think.
jones
Post  D. Sea January 7th 2010, 1:16 pm
And different type/size carb spacers Idea
D. Sea
D. Sea
Post  jones January 7th 2010, 1:31 pm
It would be cool if we could find a 100 0r 200 shot plate to try on it!
jones
Post  bbf-falcon January 7th 2010, 1:31 pm
I hope I can get mine dyno'd, and I would like a danny B to make cam timing alot simpler. Smile
Post  IDT-572 January 7th 2010, 4:37 pm
It's always a good idea to run the engine at home first if you can. That way all leaks and problems can be fixed then , and not on dyno time. Carb set, timing base set, heads retorqued, Valves set hot ect...............
I will come up and help if you need me. Wink
Post  jones January 7th 2010, 4:41 pm
I was just thinking of that. I might have to attempt to build my own break-in stand. I have some old mechancal guages I could use.
jones
