Is this a 2.3 engine?
Dr.Ford
[URL=https://2img.net/r/ihimizer/i/0103101712.jpg/]
[URL=https://2img.net/r/ihimizer/i/0103101622.jpg/]
Trying to determine because if it is, it is going back in my Courier.
Been told it's a 2.5 but now I don't believe it.
Dr.Ford- Posts : 130
Re: Is this a 2.3 engine?
Looks like a2.3 pinto / mustang 2 motor to me.
dfree383 wrote:Looks like a2.3 pinto / mustang 2 motor to me.
x2....that front sump oil pan would indicate so.
83-88T-Bird Guy- Posts : 1003
Yep 2.3
looks like a 2.3 I think the 2.5 had 8 spark plus
Yep, it is. Found out too.
Guys told me it was a 2.5L.
Now I got to fix it back up..I think the rear main seal was broken. Oil all in the front of my tranny.
It sure looks like my 2.3 turbo and the NA mill. I don't know what a 2.5 looks like though.
I know you said you figured it out but I wanted to point out the 2.3 N/A mills also had an 8 plug head
If your hunting for a new drop in look here. Lots of guys tossing N/A motors
www.turboford.net
www.turboford.net
Phil- Posts : 40
» Boat engine carb convert to drag engine
» need info asap on engine combo ( 4.3 vs 4.5 crank) ordering it by tommmorrow details inside of engine plans
» ENGINE RPM DROPS & ENGINE DIES AT IDLE & BRAKE PROBLEMS
» 653 CI Thor Headed big block Ford engine / ENGINE SOLD THANKS!!!!!
