2003 ENGINE MASTERS WINNER JON KAASE BBF FORD 468" SCJ - $10,500 Firm
mike konigshofer
This motor was built by the best in the business and is fresh with "0" run time and is ready to go. It won the Popular Hot Rodding Engine Masters Challenge and makes 745 H.P. on pump gas!
Specs and articles available upon request.
Great Engine for a Showcar or Dreamcar.
Be a part of History.
$10,500 Firm - Priced for a quick sale
mike@speednorth.com
(519)860-2565
Engine Components
Block Ford Motorsports M-6010-A460
Heads Ford Motorsports M-6049-SCJ
Crankshaft Bryant Racing 2357-1
Intake Manifold Edelbrock 2965
Carb Spacer HVH SS-4500-2
Valves Victory 1 – titanium TF/721, TF/716
Retainers Manley 23654
Spring Cups Manley 42377
Valve Locks Comp Cams 611-16
Valve Seals Universal Molded 166
Head Gaskets Cometic C-5745
Rods Carrillo 17657
Oil Pan Moroso 20625
Oil Pickup Moroso 24508
Breathers Moroso 68815
A-N Lines/Fittings Earl’s
Rocker Arms Crane Cams 27771-16
Rocker Arm Studs Arp 235-7203
Guide Plates Ford Motorsports M-6566-SCJ
Stud Girdle Jomar 1143/1416
Valve Covers Fab Sheet Metal Ford 460
Valve Cover Gaskets Earl’s EAR 29E04A
Main Bearings Clevite MS963P
Main Bearings Coating Calico CT-1
Rod Bearing Clevite CB745H
Rod Bearing Coating Calico CT-1
Cam Bearings LSM Eng. 60 MM Roller
Oil Pump Ford Motorsports M-6600-A460
Oil Pump Drive Ford Motorsports M-6605-A429
Oil Filter Adapter Ford Motorsports M-6880-A50
Misc. Engine Gaskets Ford Motorsports M-6003-A429
Rear Main Seal Universal Molded 23460
Cylinder Sleeves Darton 4.650 Blank
Main Sleeves Darton 3.250 Blank
Front Cover A.T Francis FC-429
Front Main Seal Universal Molded 5282
Water Pump Weiand 8211 WIN
Oil Filter Systems 1 512561 BP
Spark Plugs Accel 762
Spark Plugs Wires MSD 31189
Distributor MSD 8380
Bronze Dist Gear MSD 8581
Harmonic Balancer ATI 917520
Lifters Reed Cams 11115
Carburetor Barry Grant 97280-20
Wrist Pins Hoffman .990/2.930
Pistons Venolia 4881/127973
Piston Coating Calico CT-3
Piston Rings Speed Pro/Total Seal BR18PF046
Camshaft Comp Cams FF7411-7413-108
Timing Chain Set Comp Cams 3122
Pushrods Comp Cams 7918/7755
Valve Springs LSM Eng 422
Roller Thrust plate Danny Bee 1520
Cam Dowel Pins Danny Bee 1550
mike@speednorth.com
(519)860-2565
Engine Components
Rods Carrillo 17657
mike konigshofer- Posts : 9
Nevs- BBF CONTRIBUTOR
Re: 2003 ENGINE MASTERS WINNER JON KAASE BBF FORD 468" SCJ - $10,500 Firm
Will u seperate the valve covers
bbf-falcon wrote:Will u seperate the valve covers
For $10,500 you can have them
I will not separate this Master piece
Please Read the Forum For Sale Rules.............
dfree383 wrote:Please Read the Forum For Sale Rules.............
Can he bump it 19 times??
feetfirst- Posts : 139
Maybe you can vouch for me Hugo???
I understand the policy.... but crooks are crooks regardless of # of posts or time spent on a site.
Anyways, no hard feelings if you take it down...
Mike Konigshofer
Mike Konigshofer
Mike ,all you need is 25 BS posts. Just go to general discussion and post on a few of them real quick
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:Mike ,all you need is 25 BS posts. Just go to general discussion and post on a few of them real quick
Hell, go over and rag on me a little if you want. That will get you some post.
Travis
TravisRice- BBF CONTRIBUTOR
The and Fabio use to get 25 each in 1 night in 1 thread cutting on each other at the Bar & Grill
feetfirst wrote:dfree383 wrote:Please Read the Forum For Sale Rules.............
mike konigshofer wrote:ttt
Well, there's one...
Listen up guys, Mike being a fellow racer here is a stand up guy, and runs in NMCA prostock, OSCA prostock, RAM series etc. The stuff he sells is top notch stuff, the BEST of the BEST, and thats no joke!! I have bought $1000's of parts from him, and it helps he's only 10 min away...
Their family also runs in IHRA prostock, (did), and now will be in ADRL, all the while having a great relationship with J.Kaase.....^^^^^^^^^^hence the Engine Masters motor...
feetfirst wrote:mike konigshofer wrote:ttt
Thanks for the kind words Hugo...
» 2003 ENGINE MASTERS WINNER JON KAASE BBF FORD 468" SCJ
» 707" Jon Kaase Hemi Ford
» Engine Masters 414" stroker 351W street/strip engine
» Engine Masters 534 Boss Engine and BBF 72 Torino in the new PHR Magazine.
» Engine masters????
