FOx swap pan mods?????
FOx swap pan mods????? Empty FOx swap pan mods?????
Post  Tennessee Bullitt February 3rd 2010, 9:36 pm
I was moking up my fox oil pan today and it would not go all the way down over my oil pump. Does this need to be slightly banged on with the BFH? The pump is a melling 84dhv.
Tennessee Bullitt
Tennessee Bullitt
FOx swap pan mods????? Empty Re: FOx swap pan mods?????
Post  DFI429 February 4th 2010, 5:40 am
Ford truck pan? If so, absolutely. Had to ball peen my first one at the front two bolts that hit w/the HV pump.
DFI429
DFI429
Post  dfree383 February 4th 2010, 7:53 am
Ditch the Ford Truck Pan if your going racing.......
Post  Tennessee Bullitt February 4th 2010, 9:30 am
Thanks I wanted to check before I started to beat stuff up, I will get a better one laater, it's just my budget will allow certain things now, and when I get your headders DFREE I can further make sure I have good clearence. You have to remember listing to you guys I over extended my build by no skimping on the good stuff..... ie crank, rods, heads, etc.
Tennessee Bullitt
Tennessee Bullitt
Post  dfree383 February 4th 2010, 12:46 pm
All of that stuff isn't worth a hoot if you loose oil pressure.........that pan isn't good for acceleration, its shape is all wrong, if your low on bucks, modify it and box it out and add some baffles. or get a better pan......
