Big Block Fox Build
+12
89lxcoupe
Northwest outlaw
605FOX
D. Sea
511Fox
138
jones
Big block fox 339
16 posters
Page 1 of 3 1, 2, 3  Next
Big Block Fox Build Empty Big Block Fox Build
Post  Big block fox 339 February 3rd 2010, 11:58 pm
Alright here we go i started about 2 years ago with a stock 93 hatch 4cyl car that had a 5.0 in it got it for 400$ . And a stock d1ve block been saving bying parts here and and finally im almost done
engine
545''
d1ve block
scat 4.5'' cast crank
scat 6.7'' rods
probe 22cc forged pistons
10.8to1 cr
frpp c460 cam from lem
frpp lifters
lunati voodoo roller rocker
lunati push rods
comp springs
dove heads 2.25 int/1.75 ex some port work no clue on flow
victor intake
QFT 950 e85 carb
msd dist
holley 110 gph fuel pump
Tranny
c-6 man rev valve body
ptc 4000 stall
Car
93 hatchback
full interior
10 pt s&w cage
stock k-member with spacers
upr coilovers 14'' 175#
home made 2x3 subframe con
strange 8.8
full spool
33 splines
c-clip elems
upr double adj upper control arms
upr adj lowers
reinforced torque boxes
fuel cell and batt in the back
1/2 fuel line
let me know what yall think good and bad do yall think i can get it in the 10's ?
Big Block Fox Build Photo-11
Big Block Fox Build Photo-14
Big Block Fox Build Photo-8
Big Block Fox Build Photo3-6
Big Block Fox Build Photo-24
Big Block Fox Build Photo2-8
Big Block Fox Build Photo3-7
and after 6 cans of krylon spray paint lol
Big Block Fox Build Photo4
Last edited by Big block fox 339 on November 23rd 2010, 9:31 pm; edited 2 times in total
Big block fox 339
Big block fox 339
Big Block Fox Build Empty Re: Big Block Fox Build
Post  Big block fox 339 February 4th 2010, 12:08 am
Big Block Fox Build Photo-13
Big Block Fox Build Photo-12
Big Block Fox Build Photo5
Big Block Fox Build Photo2-2
Big Block Fox Build Photo-26
Big Block Fox Build Photo4-8
Big Block Fox Build Photo3-9
Big Block Fox Build Photo5-6
Big Block Fox Build Photo-27
Big Block Fox Build Photo2-11
Big block fox 339
Big block fox 339
Post  Mike R February 4th 2010, 12:46 am
Looks good. Keep the pictures coming I'll be following your build. I'm using D&D parts for my Fairmont project.
Post  Big block fox 339 February 4th 2010, 12:57 am
I got the 2'' one piece d&d header they fit perfect i stuck the motor in just to see what it looks like i bolted the headers on and dropped the whole thing in took like 15 min bymyself
Big block fox 339
Big block fox 339
Post  Big block fox 339 February 4th 2010, 1:22 am
pics of my home made torque box reinforcement kit
Big Block Fox Build Photo2-12
Big Block Fox Build Photo-28
Big Block Fox Build Photo4-10
Big Block Fox Build Photo3-11
Big block fox 339
Big block fox 339
Post  jones February 8th 2010, 11:27 pm
Looks real good Micha! You should have it running before to long!
How did the motor plates work out?
jones
Post  Big block fox 339 February 8th 2010, 11:34 pm
The front plate was perfect I used your same holes I had to make a new mid plate cause our headers were different. I still gotta put the lat limiters on run the fuel lines all that fun stuff
Big block fox 339
Big block fox 339
Post  jones February 8th 2010, 11:44 pm
Your paint job looks real good. I might have to go that route with my truck! What color did you use?
jones
Post  Big block fox 339 February 8th 2010, 11:55 pm
Its krylon rust tough semi flat spray paint it suprised me it looks like a proffessional paint job lol i used spay can primer sealer but it still scatches easy
Big block fox 339
Big block fox 339
Post  jones February 9th 2010, 12:11 am
I hope Bob at D&D didn't charge you extra if you mentioned my name when you bought the headers! LOL
If you have those headers off one day I like to see if they would fit my truck.
What size are they?
jones
Post  Big block fox 339 February 9th 2010, 12:21 am
Thier 2'' one piece with 3.5'' collector if i have to take it back out you can sure try them
finally got it sitting in the car
Big Block Fox Build Photo5-10
Big Block Fox Build Photo3-14
Big Block Fox Build Photo4-13
Big Block Fox Build Photo2-15
Big Block Fox Build Photo2-16
Big block fox 339
Big block fox 339
Post  138 February 12th 2010, 3:29 am
cool build!!
question: did you have to run the backing plate for your water pump, even with using a motor plate?
138
Post  Big block fox 339 February 12th 2010, 10:18 am
Thanks! This Is my first build but im running an electric water pump you don't have to run the ford backing Plate just the electric pump backing plate
Big block fox 339
Big block fox 339
Post  Big block fox 339 February 15th 2010, 10:25 pm
Few more pics got my control arms on fuel line ran and got is sitting on the ground
Big Block Fox Build Photo5-11
Big Block Fox Build Photo-36
Big Block Fox Build Photo2-19
Big Block Fox Build Photo3-18
Big Block Fox Build Photo4-16
Big Block Fox Build Photo-37
Big Block Fox Build Photo2-20
Big block fox 339
Big block fox 339
Post  511Fox February 20th 2010, 11:26 am
Nice car Exclamation
I love the flat black paint job.
I've seen alot of rods with the same scheme but never a Mustang.
Car looks Boss Exclamation
511Fox
Post  Big block fox 339 February 21st 2010, 11:24 pm
511Fox wrote:Nice car Exclamation
Thanks bud its 2 years in the making hope it will b running in the next month or so
Big block fox 339
Big block fox 339
Post  Nevs February 22nd 2010, 8:25 am
Big block fox 339 wrote:Thanks! This Is my first build but im running an electric water pump you don't have to run the ford backing Plate just the electric pump backing plate
I've never run a backing plate when using a front motor plate. It's redundant...
Post  Big block fox 339 February 22nd 2010, 12:09 pm
my plate has the hole in the middle for a mechanical pump
Big block fox 339
Big block fox 339
Post  Nevs February 22nd 2010, 7:22 pm
Big block fox 339 wrote:my plate has the hole in the middle for a mechanical pump
That would explain it.
Post  D. Sea February 23rd 2010, 1:02 pm
I did the same thing. It's just cosmetic but I didn't like the looks of a big hole behind the electric water pump Suspect
We are about to build Chuck's engine plate and we won't use the back plate
D. Sea
D. Sea
Post  Big block fox 339 February 24th 2010, 12:20 pm
Anybody got a Idea on what kind of et this combo might run
Big block fox 339
Big block fox 339
Post  Big block fox 339 March 12th 2010, 12:21 am
Just a lil update i got my interior back in most of the wiring done im hoping to try and fire it off saturday!!!!!!!!!! il post some pics this weekend
Big block fox 339
Big block fox 339
Post  138 March 12th 2010, 12:25 am
bounce
138
Post  Big block fox 339 March 12th 2010, 12:30 am
138 wrote:bounce
tell me about it !! this is my first car and its 2 long years in the making
Big block fox 339
Big block fox 339
Post  Big block fox 339 March 21st 2010, 7:43 pm
Here is a lil up date hope to crank it next weekend!!!
Got my anti roll done all my wiring ,koni struts installed ,int back in, all my gauges are done
All i like is getting the driveshaft cut and rearend built and the break in
Big Block Fox Build Photo-38
Big Block Fox Build Photo2-21
Big Block Fox Build Photo3-19
IMG]https://2img.net/h/i635.photobucket.com/albums/uu78/bigblockfox/photo5-13.jpg[/IMG]
Big Block Fox Build Photo-39
Big Block Fox Build Photo2-22
Big Block Fox Build Photo3-20
Big block fox 339
Big block fox 339
