D3 head question
D3 head question
This might be obvious to some, but anyway.
What is the best way to go about cleaning up all the metal grit up after grinding on the heads? Compressed air and a shop vac?
I just want to be sure all metal shavings are gone.
OldRedFord- Posts : 465
Re: D3 head question
The same way you would when cleaning a block.
Compressed air,good degreaser
Soap/hot water
compressed air
Soap/hot water
compressed air
Will the factory valve spring retainers work with the Ford Racing M-6513-A50 springs?
OldRedFord wrote:This might be obvious to some, but anyway.
Big welding magnet, dont want that stuff getting in strange places like your lungs or your freshly machined bores or what have you. Actually now that I think about it an electro magnet would be better, just unplug it over the trash can and the filings just fall off.
torkair- Posts : 404
I think if you got your heads or block even remotely magnetized you would be in world of hurt... until you could reverse it.
138- Posts : 1593
X2 only way to get it clean.bbf-falcon wrote:The same way you would when cleaning a block.
Soap/hot water
compressed air
95lightiningguy- Posts : 570
» TFS A-460 head question
» head question
» Another head question.
» A 460 Head Question
» Head question
» head question
» Head question
