stock block 460
BBFmustang
bbf_coupe
stock block 460
ca a stock 460 block hold this combo? 466ci, p51 heads, big solid roller,1050 carb, and max spray of 300 shot???? thanks
bbf_coupe- Posts : 11
Re: stock block 460
better have a good tune for the nos
BBFmustang- BBF CONTRIBUTOR
Re: stock block 460
I think you would be pushing your luck if you don't look into some main caps , you are talking about in excess of 1000hp there easy.
KY JELLY- Posts : 1530
Re: stock block 460
So let's back it down a bit, let's say that setup on a 200 shot. If I get good aftermarket main caps, would a stock block be ok with all studs and girdles. My goals is the motor above in my mustang to go 5.70-5.99 in the 1/8. Will it work or do I need to go a different route?
Re: stock block 460
Can it work? Yes. Will it last? No. You are going to be replacing the bearings on a regular basis. The caps will help, hard block will help, but there is no replacement for a good A460/Eliminator style block. Either lower the expectations, or live with the maintenance. Cheap, Fast, Reliable, choose one.
schmitty- Posts : 4538
Re: stock block 460
We are running a stock CJ block 521 with factory CJ heads in a 2800 lb. 73' mustang. It has been 5.90 on motor. I think with P-51's you wouldn't need to spray to get those E.T.'s, unless you just wanted to. The block has been poured, with the 4-bolt mains. This engine has been a race engine since 1992. It has literally a couple thousand passes on it, with quite a few rebuilds of course. I'm actually in the middle of a freshen-up on this engine right now.
BigDave65- Posts : 567
Re: stock block 460
Wow, if I could get a 5.90 on motor, I would not even think about spraying. I'll be honest, I figured a stock 460 block could handle alot more but evedently not. I've pounded on a stock block 347 and no problems yet. So a all motor 466 with p51 heads would be preffered in a aftermarket block? Correct?
Re: stock block 460
I think you may have misread, but you can achieve your goal of 5.90 on motor no problem with P-51 heads on a stock block. The main factor will be the car set up, stall, weight, gear, etc.
I'm pretty sure there are LOTS of guys going that fast with stock blocks...lots. I think you are, however, getting close to time you would want to consider going to an aftermarket block, especially if you'll want to spray it. People always want to go faster.
Let us know...and good luck!
windsor- Posts : 1167
Re: stock block 460
ok, yea my car is alittle over 2800 pounds, full 10 point cage, all tied together. it leaves straight and i will be going with a glide. ill let everyone know the results..... hopefully they will be good =]
Re: stock block 460
I think a stock block will handle a na 466 p-51 , but on 300 spray every pass not likely to last .
Re: stock block 460
yea, im leaning heavily on all motor for now
» question about stock 1971 stock block
» Differences between stock type block and the a460 block?
» how much hp on stock block?
» stock block
» just thinking out loud!
» stock block
