Removing oil filter stud
Tore
I want to remove the oil filter stud in my engine and it doesnt have a hex to grab like some I have seen. How do you get the ones out without the hex? Some heat and a Vice-grip?
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: Removing oil filter stud
Yea,Tore if it's that tight,you may have to heat it. If you don't care about ruining it ,you can put a pipe wrench on it. Shaun has the hex heads in stock.Good luck my friend
Tore,
Get some true "jam" nuts, they are thinner. Use a couple and some heat, and it should come out without destrying anything.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
c.evans wrote:Tore,
Charlie
That's what I did. It just so happened that the jam nuts from my heim ends on my adjustable upper control arms are the same size and thread pitch.
83-88T-Bird Guy- Posts : 1003
Make sure its not the type that takes a allen wrench.
342g- BBF CONTRIBUTOR
» Help Removing 460 block
» Removing brake booster
» Removing pilot shaft bearing
» Whats good for removing oil/grime off frame
» Options for removing strut towers?
