pressure in rad ???
pressure in rad ???
so i pulled the heads off the 460 today and i could not see any obvious leakage thru the head gaskets. couldnt see any cracks in the heads and the cylinder walls look fine.is there any other place i should look or would a leak in the head gasket be very hard to see.last time i had a head gasket leak it was very easy to find. stock d3ve heads.i got it pretty hot last fall when my fans shorted and quit. probably around 280 or more.
bronco- Posts : 104
Re: pressure in rad ???
i would have the heads maged it might have cracked one and you can't see with the eye might be cracked in a valve port
Jim
Jim
ok. thank you
bronco- Posts : 104
