Delay box for bracket racing
+14
bcr466
138
342g
paulie9fingers
Treeyasoon
QtrWarrior
badnotch
mustangjeff
18 posters
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: Delay box for bracket racing
Ya can't miss him. He's got the WHITEST legs in the pits Sorry Harold Forgive me Lord,and all those pygmy's down at Edgewater
342g wrote:mustangjeff wrote:Well guys I guess I am a p***y, but I bet I could put bad notch on the trailer the first round. Oh wait a minute it is probably not even fast enough to require a trailer. Thanks for the help from the rest of you guys.
Don't have to worry about him, he can't get a car to go down the track.
your so funny - one time out of 62 - if you want some just call me out peter
maverick wrote:Back to the original question........I use a skuzzy old Dedenbear SCO1. Nothing fancy. Reliable as an anvil. Allows 3 hits on the tree if you're so inclined (I am not). My favorite use of the box is crossing over and leaving off the slower guy's top bulb. Had lots of success that way.
Dont have to use their bulb here, all our tracks use crosstalk.
I guess that might be true sometimes. On the other hand around here you see a lot of guys double tech their cars in both box & no-E classes on the same day with success. So obviously some guys have to have the box, and some box guys can work both with and without the delay box like clock work.badnotch wrote:kinda funny the ones that do use them wont race without them ~~~
Speaking of the cross over box, what about the bad old days before cross over's where invented when you had to keep a calculator in the car to quickly figure both dials to leave off a slower guy's tree?
DILLIGASDAVE- Posts : 2262
I bet there were guys back then who claimed that using a calculator was cheating.
maverick- BBF CONTRIBUTOR
But they were using scientific TI's. LOL
Curt- Posts : 2791
what about the good old days when nobody ran electronics and had to cut a light AND build a car that run the number!
Hey notch, peter here, come on down to e-water, bring your wallet.
342g- BBF CONTRIBUTOR
cool40 wrote:what about the good old days when nobody ran electronics and had to cut a light AND build a car that run the number!
we have no electronic classes here as well, not so sure that bunch is any easier pickin's.
a delay box just makes a good racer better
KY JELLY- Posts : 1530
342g wrote:Hey notch, peter here, come on down to e-water, bring your wallet.
lmao
I use a Bondio but want a K&R, for bump down & bump up feature on two diff switches. I run No-Box (box velcroed in with trailer plug) also with good results, I found you have to find your place on the tree and adjust the car to leave and cut a light in No Box. Never try to adj yourself, you will never as consistant as the car. I shoot for a .01 to.02 light off the bottom if I got a tough race I may bump in just a hair more to go .00 but with that the ET may change may have to drive the big end more than normal,with the box I shoot for .002/.007 try to keep a .005 spread. I do use a practice tree which is hooked to the car electronics which I try to keep a .005 spread also. I prefer Box class I don't know why I guess there is more $$$$$$$$$$$ in it
BIGDOG466- Posts : 265
BIGDOG466 wrote:I use a Bondio but want a K&R, for bump down & bump up feature on two diff switches. I run No-Box (box velcroed in with trailer plug) also with good results, I found you have to find your place on the tree and adjust the car to leave and cut a light in No Box. Never try to adj yourself, you will never as consistant as the car. I shoot for a .01 to.02 light off the bottom if I got a tough race I may bump in just a hair more to go .00 but with that the ET may change may have to drive the big end more than normal,with the box I shoot for .002/.007 try to keep a .005 spread. I do use a practice tree which is hooked to the car electronics which I try to keep a .005 spread also. I prefer Box class I don't know why I guess there is more $$$$$$$$$$$ in it
and if you try to compete in a tight class with out a box my experience is you go home early alot....
the Coug- Posts : 3055
the Coug wrote:BIGDOG466 wrote:I use a Bondio but want a K&R, for bump down & bump up feature on two diff switches. I run No-Box (box velcroed in with trailer plug) also with good results, I found you have to find your place on the tree and adjust the car to leave and cut a light in No Box. Never try to adj yourself, you will never as consistant as the car. I shoot for a .01 to.02 light off the bottom if I got a tough race I may bump in just a hair more to go .00 but with that the ET may change may have to drive the big end more than normal,with the box I shoot for .002/.007 try to keep a .005 spread. I do use a practice tree which is hooked to the car electronics which I try to keep a .005 spread also. I prefer Box class I don't know why I guess there is more $$$$$$$$$$$ in it
So, I guess what you're saying, Randy, is that the P*****S get to stay and race into the later rounds?
maverick wrote:the Coug wrote:BIGDOG466 wrote:I use a Bondio but want a K&R, for bump down & bump up feature on two diff switches. I run No-Box (box velcroed in with trailer plug) also with good results, I found you have to find your place on the tree and adjust the car to leave and cut a light in No Box. Never try to adj yourself, you will never as consistant as the car. I shoot for a .01 to.02 light off the bottom if I got a tough race I may bump in just a hair more to go .00 but with that the ET may change may have to drive the big end more than normal,with the box I shoot for .002/.007 try to keep a .005 spread. I do use a practice tree which is hooked to the car electronics which I try to keep a .005 spread also. I prefer Box class I don't know why I guess there is more $$$$$$$$$$$ in it
Yep 10-4
I tried it and tried it without a delay box and after a few times I said time to get a delay box, and run with them.....
Oh around here tring to run Box Class without one, yea your going to be loaded up!!!!!!!!!!!!! If I know someone doesn't have a box I'll go duck huntin roll ten in mine and send him to the trailer.
Go to the "Million" @ Indy this year and see how many are there w/o one.
Treeyasoon- Posts : 759
Treeyasoon wrote:Go to the "Million" @ Indy this year and see how many are there w/o one.
Wutta buncha P*****S.
maverick wrote:Treeyasoon wrote:Go to the "Million" @ Indy this year and see how many are there w/o one.
yeah I agree but they are not Career TNT guy's
I am taking donations for the entry fee to the million
BIGDOG466 wrote:Treeyasoon wrote:Go to the "Million" @ Indy this year and see how many are there w/o one.
Are you going to run a delay box?
342g wrote:BIGDOG466 wrote:Treeyasoon wrote:Go to the "Million" @ Indy this year and see how many are there w/o one.
YEA
» Bracket racing
» Racing question ....for the bracket guru's
» Bracket racing
» NMRA Bowling Green, KY racers...no more Bracket 1 or BK 2
» The Drag(ster) slayers
» Bracket racing
Page 3 of 3
