Dowel Pins
BigDave65
Dowel Pins
Was wondering if you guys had any slick ideas to remove the tranny dowels from the back of the block. I have a CJ block we are using a mid-plate and JW bellhousing and really need to use longer dowels to locate the bellhousing. Are the factory dowel pins soft enough to just drill out? Thanks in advance!
BigDave65- Posts : 567
Re: Dowel Pins
Vice Grip pliers, or a hammer and punch will usually do it.
schmitty- Posts : 4538
Re: Dowel Pins
I have used vise grips and clamped them and took a hammer and tapped them out usely not that hard to get out have had them stay in the trans when pulling the trans
Re: Dowel Pins
I've tried vise grips and they wouldn't budge. These things are stuck pretty good. I'm still open for any suggestions. Thanks again guys.
Re: Dowel Pins
Are they sticking out far enough to get on them with a stud remover???
Re: Dowel Pins
Take a propane plumbers torch and heat the block around where the dowels are, don't heat the dowels though, should loosen them up a little. If you do get heat on the dowels, just put an ice cube on the dowels to cool them and they should come free.BigDave65 wrote:I've tried vise grips and they wouldn't budge. These things are stuck pretty good. I'm still open for any suggestions. Thanks again guys.
Re: Dowel Pins
Or after the flame from the torch is out... a little canned air through a tube will isolate some cooling, but only after the flame is OUT. LOLschmitty wrote:Take a propane plumbers torch and heat the block around where the dowels are, don't heat the dowels though, should loosen them up a little. If you do get heat on the dowels, just put an ice cube on the dowels to cool them and they should come free.BigDave65 wrote:I've tried vise grips and they wouldn't budge. These things are stuck pretty good. I'm still open for any suggestions. Thanks again guys.
longroofracer- Posts : 250
Re: Dowel Pins
drill a hole in it tap it and use a slide hammer to remove them....
the Coug- Posts : 3055
Re: Dowel Pins
Some of them can be a bitch
Re: Dowel Pins
Use heat from a torch and vice grips.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
» New Cam Dual Dowel Pins?
» What size dowel pins go in block for heads sit on bbf
» Cylinder Head to Block Dowel Pins
» what size are the dowel pins in the DIVE block to transmission
» A460 main cap pins - what are they for, locating, cap walk, ?
