Belt Driven Oil Pump (Non dry sump)
+10
kim
Bsherry
racnrick
14 posters
Page 2 of 2 Previous  1, 2
Belt Driven Oil Pump  (Non dry sump) - Page 2 Empty Re: Belt Driven Oil Pump (Non dry sump)
Post  windsor August 26th 2009, 4:46 pm
Great pics and intel, gents. I really like the idea of getting the pump out of the pan...I also like the 'symmetry' it would add to the engine with only running an alternator.
I'll be running a Mustang II style front end in my 65 Falcon. I know this is generally rear sump. Would a custom oil pan be able to be made that is much shallower in the front area where the oil pump would originally have gone to allow the motor to be set lower?
Post  dfree383 August 26th 2009, 5:02 pm
From the must II stuff I've seen the location of the Rack is usually behind the location of the pump area of the pan. Not sure you gain anything, unless you going to do a way set back installation?
Post  windsor August 26th 2009, 6:02 pm
hmmm...I can't seem to find any pics at the moment of a MII in a Falcon...but this is another pic of a K-member in a 65 Falcon with a small block motor...crossmember would be in about the same place.Belt Driven Oil Pump  (Non dry sump) - Page 2 P5290211
Post  Lem Evans September 8th 2009, 9:15 pm
Post  665 falcon September 9th 2009, 8:23 am
Lem Evans wrote:Belt Driven Oil Pump  (Non dry sump) - Page 2 BZ588001Small
Belt Driven Oil Pump  (Non dry sump) - Page 2 BZ588002Small
Pan converted for an external pump .
Man thats a nice converted job there Lem. wink, my smilleys are disable for some reason. Bobby Z
665 falcon
665 falcon
Post  jasonf September 9th 2009, 10:57 pm
windsor wrote:hmmm...I can't seem to find any pics at the moment of a MII in a Falcon...but this is another pic of a K-member in a 65 Falcon with a small block motor...crossmember would be in about the same place.Belt Driven Oil Pump  (Non dry sump) - Page 2 P5290211
hey windsor, do you have anymore info on this falcon?
Post  windsor September 10th 2009, 10:12 am
Hey Jason... a guy from yellowbullet sent me that when I was asking about Kmembers for classic mustangs/falcons. He built it himself and says he can make more. That's a small block motor but don't have any other info on it.
Post  jasonf September 10th 2009, 1:15 pm
I like all his bracing underneath to add strength. It is similar to what I have done but looks nicer. Very Happy
