vacuum pump line
vacuum pump line Empty vacuum pump line
Post  simpleman May 7th 2010, 10:27 am
Will changing from a 12an to a 10an vacuum pump line affect the pull it has on the motor? I need to move to the smaller fiitings due space constraints? The vac is controlled by a moroso relief valve.
simpleman
simpleman
vacuum pump line Empty Re: vacuum pump line
Post  whatbumper May 7th 2010, 11:57 am
Yes, it will effect the amount of air that the pump can flow. The smaller the line the more drag on the pump, but the -10 will probably be fine though it will flow less air. Do you have one or two lines to the motor? The motors size, horsepower level, power adder, ring package, rpm, and fuel type all determine the airflow needed by the pump. How much vacuum do you like to pull and how far open is the relief valve?
Post  simpleman May 7th 2010, 12:31 pm
c headed 632. q16. low tension rings setup by Jet Boat. no power adders. just one line from a valve cover. might move it to pull from the valley pan on the intake. I adjust it to pull almost 10lbs on the gauge
simpleman
simpleman
Post  whatbumper May 7th 2010, 12:49 pm
Most companies will advise you to go to two -10 lines or stay with the -12. With a low tension ring package on that large of an engine you need to be able to evacuate lots of air. Is there anyway to clock the pump differently to keep the large fittings? Just a thought.
Post  simpleman May 7th 2010, 2:51 pm
May have do a little clearancing. Probably shouldn't change what is working. Smile
Thanks you Mr. whatbumper!
simpleman
simpleman
