Carb Size for 504 cubic inch?
+12
boss56
feetfirst
BB94STANG
DaveMcLain
1Bad91
16 posters
Carb Size for 504 cubic inch? Empty Carb Size for 504 cubic inch?
Post  1Bad91 June 20th 2010, 10:14 pm
I currently run a 1000cfm 4150 carb and few friends telling me i need a 1050 Dominator for my motor. What do you guys recommend? Thanks
1Bad91
1Bad91
Carb Size for 504 cubic inch? Empty Re: Carb Size for 504 cubic inch?
Post  Lem Evans June 20th 2010, 10:15 pm
What are you doing with it ?
Post  1Bad91 June 20th 2010, 10:35 pm
Street/strip car. 80% strip 20% street
1Bad91
1Bad91
Post  Lem Evans June 20th 2010, 10:42 pm
Will depend on the intake manifold and other things but, generally a 1050 4500 is the ticket. Will need to be with a primary p.v. for the street driving.
Post  dfree383 June 20th 2010, 10:59 pm
IMO you don't "need" a 1050 dominator, but like Lem has said they are the ticket and generaly make more power than the 4150 stuff.
Are you unhappy with your 1000 4150? Is it not working?
Post  1Bad91 June 20th 2010, 11:00 pm
it's a 4150 victor manifold but planning to work it to a 4500 set-up. Filling the holes and make new ones for the 4500. Also cleaning the inner portion of the manifold to match. Would this help me or would it not?
1Bad91
1Bad91
Post  dfree383 June 20th 2010, 11:02 pm
Yes it will make more power.
Post  1Bad91 June 20th 2010, 11:04 pm
dfree383 wrote:IMO you don't "need" a 1050 dominator, but like Lem has said they are the ticket and generaly make more power than the 4150 stuff.
No, it's working fine but many people telling me the dominator will help alot at WOT. Some say I could pick up 2 tenths if not more. I want the most out the motor ya know what i mean
1Bad91
1Bad91
Post  dfree383 June 20th 2010, 11:07 pm
Then you "need" a Dominator...... Laughing
Post  1Bad91 June 20th 2010, 11:14 pm
dfree383 wrote:Then you "need" a Dominator...... Laughing
How so?
1Bad91
1Bad91
Post  BOSS 429 June 20th 2010, 11:52 pm
if you want max power a 1150 or larger,depending on your engine specs will be better,
i have a drive anywhere 508 10.5 72 torino, 1150 dom, ive tested 6 different manifolds,and countless carbs, its a street car 4200lbs, ive even had a factory low 2x4 intake on this car.
dom works best
Post  dfree383 June 21st 2010, 6:42 am
How so?
Better fuel distribution and fuel atomozation over typical 4150 stuff...........WOT you will definetly have a nice improvement, But if its a true street car and your looking for some semblence of fuel economy, great part throttle response, Etc. ..... the 4150 stuff is the ticket.
Mostly Track Car = Dominator IMO
Driver (Real one) = 4150 IMO
They both have merit in the correct application.
Post  bbf-falcon June 21st 2010, 6:45 am
Has alot to do w/engine combo,Heads and Flow,Cam,intake,etc. If you have to buy a new Dommy I would go w/1150. JMO
Post  DaveMcLain June 21st 2010, 8:37 am
I'd say that the amount of improvement you'll see all depends upon how well the engine runs right now. I don't think you'll see 2 1/10's improvement even in the 1/4 mile and certainly not in the 1/8th mile, I'd say more like 2 1/000's ET would be realistic if the engine makes say 700 horsepower right now.
DaveMcLain
Post  BB94STANG June 21st 2010, 10:25 pm
My 502 made 719HP with a BG 850 Demon. Changing to a QF 1150 dominator netted 740HP. 21HP over the BG but torque was up closer to 30. Torque curve was more broad with the dominator and Egt's were better. The 850 seamed to lean out some of the outer cylinders.
I have an adaptor fot the intake if you would like to try it out. That way u don't have to cut the intake up if you decide not to go that way. Just borrow a dommy and try it ...the only way you will know. Just pay shipping and send it back when you are done with it.
BB94STANG
BB94STANG
Post  1Bad91 June 21st 2010, 10:53 pm
BB94STANG wrote:My 502 made 719HP with a BG 850 Demon. Changing to a QF 1150 dominator netted 740HP. 21HP over the BG but torque was up closer to 30. Torque curve was more broad with the dominator and Egt's were better. The 850 seamed to lean out some of the outer cylinders.
Very nice of you. I bought one and I have a 1050 dom I'm borrowing from a friend. I would hope to see a tenth atleast. If not, it wont be worth it for me. Not to go through all the trouble anyways.
1Bad91
1Bad91
Post  BB94STANG June 21st 2010, 10:58 pm
opening up the carb pad to a 4500 will help even more but this will give you an idea. The adaptors really look like it chokes way down then that air/fuel mix has to make one hell of a turn into the runners.
BB94STANG
BB94STANG
Post  1Bad91 June 21st 2010, 11:00 pm
yeah i looked and felt the same way. If i pick up sometime I think I will swap either way. Big motors need more gas. I should have done that to begin with
1Bad91
1Bad91
Post  BB94STANG June 21st 2010, 11:02 pm
good deal...Be sure to post up the results.
BB94STANG
BB94STANG
Post  1Bad91 June 21st 2010, 11:18 pm
Def will
1Bad91
1Bad91
Post  rmcomprandy June 22nd 2010, 9:46 am
IF your present carb is working up to potential then 2 tenths is a "pipe dream" ... manifold mods will help more. Your present manifold can be modified to accept BOTH type carbs.
Post  IDT-572 June 22nd 2010, 5:36 pm
Open the manifold to 4500 base, radius ( as big a radius as you can ) the runners entries, then match the plenum to a 1 inch four hole to open super sucker. then add the 1050 4500 dommie.
All this needs to be done to maximise the change. Then if your 4150 tune realy sucked, you might see the 2 tenths your talking about.
Post  1Bad91 June 22nd 2010, 6:34 pm
It's really hard to say how bad the carb did, but keep in mind im going off of what most big block users run. And in this case it's a dommy!!
1Bad91
1Bad91
Post  richter69 June 22nd 2010, 6:38 pm
IDT-572 wrote:Open the manifold to 4500 base, radius ( as big a radius as you can ) the runners entries, then match the plenum to a 1 inch four hole to open super sucker. then add the 1050 4500 dommie.
right on Blake...remember the Nova that made me a HeRo a month ago by gaining 8 tenths and 10 mph going from gas to alky, well he's getting a built gas carb for it...I venture a guess he will see double the 2 tenths gain lol.
Post  1Bad91 June 22nd 2010, 6:48 pm
But I cant complain too much because that 4150 won me $13000 and a Pinks all out Victory...lol
1Bad91
1Bad91
